Gas leak - Is changing hose first step? (4 Viewers)
themountaintiger
355
63
Lancashire
Swift Kon-Tiki 649C Class
Since 24th March 2010
Hi all
Got a gas leak. No smell whatsoever in hab area, but its being used too quickly based on previous use. I've read on here that it might be an issue with the hose from bottle to regulator. Is this something I could change myself or is a gas engineer required to do it?
If the replacement hose doesn't solve the issue, could it be the regulator? Is that something I can replace?
Thanks for any responses...
T
ukbill
5,501
5,274
Pinoso
4 berth low profile
1st step will be to check all connections are tight is this a gasit alugas system or a normal calor
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
It's quite simple to change the hose. After all it's almost what's involved when you change over cylinders. Just a matter of swapping one for the other. The metal reinforced replacement hoses have a longer life span than the plain rubber ones. Of course it could be a problem elsewhere in the system but that is the easiest place to start.
Wyn
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
You haven't said what system you are using Calor or refillable. Got to be the first step.
19,743
52,073
uttoxeter
ambulance conversion
50 years
Doesn't really sound like a leak to me, if it's going that fast you notice a change in use age there has got to be a smell somewhere, are you sure it's not just having the heating on more with this cold we've had , soon eats into your gas.
MattR
4,105
39,029
Beds
Panel van
Years
If your fridge on? We went through a bottle in record time last summer as the fridge was using more gas than usual due to us putting items on the floor of the cupboard immediately above the fridge and it went into overdrive.
themountaintiger
themountaintiger
355
63
Lancashire
Not more usage based on previous history. I seem to be getting through a 6kg calor bottle in 3 weekends away.. (off ehu). I've not been doing anything differently like leaving gas fire on overnight so to speak..
themountaintiger
themountaintiger
355
63
Lancashire
Yes fridge is on. Not sure about this one. fridge going into overdrive. I'm thinking do the easiest thing first.. i.e. check the hose to calor bottle and if thats ok, time to get fridge/gas serviced I think.
967
3,361
Gas is heavier than air ... therefore if a leak is on a pipe outside the locker or Hab area then it may drift off in the wind and no apparent smell would be had........ but gas smell is very distinctive and apparent and you would sense it, even a small leak if you had the van in a garage/shed should be sensed. The bubble test is good and should show it even if the leak is small. I have in the past pressurised the system and left overnight to see if the pressure drops but you require equipment to perform the test.
Hope you get it sorted soon..... assuming you have an issue.
19,743
52,073
uttoxeter
50 years
Are you sure the bottle was actually full to start with, no garauntee, plus don't know what you use it for but we can empty a 6 kg bottle in a week , just the two of us , cooking water heating fridge, and heating if it's cold.
MattR
4,105
39,029
Beds
Panel van
Years
Check the outside wall where the fridge vent comes out of the mh - ours was warm / hot due to the excess amount of heat being generated.
53,501
150,330
I agree it doesn't sound like a leak to me either, normally you can smell very small leaks.
If the fridge has a nice clean blue flame & it is cooling OK it probably OK.
We seem to use more gas every year and I can't work out why, last September got through 26Lt in 2½ weeks, didn't think we used the heating much. Was the first time we had used the new van for longer periods in our case I blame the Dometic 8 series fridge sure it uses a lot more gas than the 7 series, lot bigger flame & sounds like a furnace.
themountaintiger
themountaintiger
355
63
Lancashire
Are you sure the bottle was actually full to start with, no guarantee, plus don't know what you use it for but we can empty a 6 kg bottle in a week , just the two of us , cooking water heating fridge, and heating if it's cold.
I believe I've had this issue with last 4 bottles from different retailers. At first id thought id got one that wasn't full as it was a calor gas lite replacement due to recall. Sort of forgot about it till 2nd then 3rd bottle used quickly. Interestingly my 3 weekends away per bottle isn't far off your usage. is it all in my head? Need to get washing up liquid out..
MattR
4,105
39,029
Beds
Panel van
Years
We've just returned from a tour of Mull and used approx 6kg of gas for the fridge, cooking and a little water and air heating over 10 days.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
I bought this gas tester for about twenty odd quid a few years ago..worth its weight in gold
DanielFord
3,020
3,086
It doesn't sound too excessive to me, in 2 weekends away, we burned through a 6kg! Wife does like to be toasty warm though, so heating left on low through the night, and cooking a roast in the oven on a Sunday.
To answer the original question though, changing the pipe is dead easy, the rubber stuff is not that expensive, and can be picked up by the metre in most BBQ sales places. As others have mentioned, you may want to go braided steel to improve lifespan?
themountaintiger
themountaintiger
355
63
Lancashire
hmm did the bubble test.. nothing.. no bubbles.. checked on motorhome wall on other side of fridge.. very cold. Think I'm better getting fridge/gas service and tell engineer i'm unclear whether using too much gas... perhaps its just my incorrect perception of my gas usage.
Big Lad
106
74
Tamworth
Lunar Roadstar 570E
If in doubt, it always pays to have your gas system fully checked for that piece of mind.
I've had my motirhome 6 months and basically been getting it ready for trips out this year.
Although the dealer said they'd carried out their own habitation check, i paid for a full gas test for my own piece of mind - so glad I did, as the pig tail was 5 years out of date and there was a gas leak off the pipework in the locker.
All sorted now, with a full bill of health, a certificate.
43,348
49,550
The reg hose will/should have a date on it.
cant remember if its a "replace by" or "manufactured" date but needs replacing every 5 years.
Most likely a "manufactured" date
Big Lad
106
74
Tamworth
Lunar Roadstar 570E
Apparently it's the manufacture date you go off not when it is fitted... bit silly in my opinion as I thought the pipe only started to deteriorate once fitted?
967
3,361
You need one of those ebay jobs.
You can squeeze 7 litres into a 6 litre bottle !:whistle:
:reel:
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
Never mind bubble tests and all that rubbish. The best way is "Light a match run it along sides of pipes hoses etc. When it goes "BANG" you have found the leak problem solved "SIMPLES" fun!!! fun!!! fun!!!
679
785
South Essex
15 in MH, 15 in Caravan
If it helps, we used a whole 6kg bottle in 4 days recently...
This was cooking, water and air heating and the fridge... and I thought I only had the heating on low (18°) compared to others I've heard of (20°+)...
