Gas it Filter (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Should i include an inline Filter in my Gas it instalation.
Do you get much dirt etc from gas with a refillable system ?
Just trying to justify the extra £40+
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
Only from reading some threads about it and I emphasise no experience, but abroad seems to have a few snags because of the mixture of propane and butane, but someone also stated they have filters fitted, but have never had any debris at all - only think it was @Techno ? Gaslow have internal filters in the bottles and this was why I went for these and not Gas It, but £40 gives you piece of mind, but remember to inspect and clean and or replace. Just more routines to remember and carry out.
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
We have a gas it system without filters not had a problem.(y)
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
what sort of money is a new regulator ,, & do regulators not have filters in them ? , as id be worried about a small bit of dirt getting into an appliance then it costing a fortune to get rectified.
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
we had a fridge jet blocked and a propex pack up a few months after we had a underslung tank fitted it may have been coincidence but i would have the filter
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
@Speve Alan have you filled up in europe much or just the UK ?
Yes we have just spent three months over there filled up a couple of times and had Hab check done last month all ok and we used all the gas appliances including heating.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
@Speve Thanks Alan
I think filter it is then.
I'd kick myself i think if something went poop :cry:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yes when I replaced my old tank I stripped the filter and the element was clean as a whistle. I don't have a filter now.
I did fit one initially but have since moved the regulator to the gas locker and piped straight off the tank in 10mm
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
@Speve & @Techno thanks guys :)
So just to make sure this is right
So this filter will screw directly onto the outlet valve of the tank
http://www.gasit.co.uk/gas-it-direct-gas-in-filters-d-g-i.html#
Then this hose will connect it and my regulator together ( i will remove the existing orange hose and connect the new black hose to the top of the regulator )
and a pic of my regulator below
Does that look like it will all screw together corectly ?
Minxy
32,659
66,565
E Yorks
Carthago Compactline
We've had a refillable gas cylinder system since 2009, putting in 350 litres, mainly abroad and have never ever had any problems, however we did fit the stainless steel hoses rather than the rubber/composite ones.
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
@Bart the adaptor that I linked was one that screws to your filling adaptors so that you filter as you fill your tanks, you don't need to change pipe work just screw it to your fill adaptor or fill point.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Ahh i see :)
