Gas hob failure (1 Viewer)
Mar 17, 2013
389
389
Devon
Carado T339
Our largest gas ring has stopped functioning for some reason. Lots of clicking and gas coming through but no ignition. Other two rings are fine - any ideas anyone?
meanders
Funster - Life Member
2,611
8,448
Ipswich, Suffolk
C class
Since 2004
Can you light it with a match? If yes, the problem is with the igniter or electrode. If no, its the flame failure device (thermocouple).
Please post back the make and model of the cooker/hob and the answer to the above so we can advise further.
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
The spark needs to go to earth to believe it or not make a spark, the noise you hear is it happening. The ring that doesn't light may not have a good earth, try moving it around if you can to get it to earth.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Hey I got a problem like that! Hob lights, but as soon as you release the button it goes out, (the button you hold down for 20-30 seconds before you release)
Any Ideas?
Feb 24, 2013
13,083
101,452
Bolsover, Derbyshire
Hymer S800
not long enough
how about the metal thingie in the middle, if slightly off line it will not light
had that ourselves at home and in MH typically after cleaning (y)
landscaper
Mar 17, 2013
389
389
Devon
Carado T339
Thank you - wriggled the hob and it is working.
Appreciate all the feedback and help from everyone!
Mar 23, 2012
9,548
32,107
sleights
c class
Next time check theres no water on the hob top if it gets inside the burner it stops working.
