955matt
First time on the euro tunnel with the camper at Christmas, what are the rules for gas bottles , we have two 13kg bottles on board.
Thanks Matt
Thanks Matt
If the vehicle is propelled by gas (as in American RV's) they won't let you on.
They have never asked me to turn my tank off at the airbox, quite happy that it is valved off in the old gas locker.
They just want to be sure you are not burning gas.
I have a similar arrangement fitted by Autogas200 however I believe the label is a Eurotunnel requirement.They have never asked me to turn my tank off at the airbox, quite happy that it is valved off in the old gas locker.
You are very welcome to cop a feel it does not waggle it is solid.Andy, pardon me for questioning your ability, but shouldn't the top of the pipe have a bracket on to hold it still so that it can't 'waggle' at the joint into the isolation tap - the joint is not meant to hold it other than to join the 2 pieces together ... having had a fire in a MH due to a bad gas bbq installation by a dealer where the pipe wasn't properly secured and so had come out of the joint eventually I would be very concerned if this was in my van ... please consider putting on at least one extra bracket, preferably 2.
Make sure you have dials (ebay) fitted which show the amount of gas which shouldn't exceed 80% and as most systems like Gasflow won't fill above that figure you should be OK. Remember No Reader NO GOThanks for the replys I was just worried about the 80% full thing.
Cheers Matt
... what about in transit ... below are photos of my gas pipe before the 'flamethrower' experience - it was solid to the touch and had had a habitation and gas safety check less than 2 months before the pipe pulled out of the joint .... you should NOT rely on the joint to keep it in situ, that's what brackets are for.You are very welcome to cop a feel it does not waggle it is solid.
Sorry but you do NOT need a reader ... in all the years we've been going abroad, both on ferry and Eurotunnel, we have never ever been questions as to the quantity of gas in the bottles, only whether they are on or off.Make sure you have dials (ebay) fitted which show the amount of gas which shouldn't exceed 80% and as most systems like Gasflow won't fill above that figure you should be OK. Remember No Reader NO GO
I have never encountered them checking the quantity.
It never happensSorry but I think your wrong
From the Chunnels own website. The highlight in red is mine
Fixed gas containers (tanks, etc.)
For the purposes of this text, this means fixed containers that are permanently installed or fixed in a vehicle and are refillable from outside the vehicle.
The quantity of gas is limited to 47kg (or approximately 93 litres) maximum for a single container and to 50kg (or approximately 99 litres) maximum in the case of several containers. Each container must be no more than 80% full.
The quantity will be checked via the gauge or remote indicator but if neither are present, the vehicle will be refused.
correctMe either - and since most systems don't have a measuring gauge there would surely be droves of MHs and caravans being turned around if it were the case that you had to prove that it was less than 80% full.
