Gas Bottle options (2 Viewers)
dellwood33
878
Newcastle
italian crap
too long
Newbie question here:
I will be needing gas bottles for the motorhome and according to the specifications it takes 2 x 6 litre bottles.
Which is the best type - Red or Blue
Any particular manufacture
I will not get to see what is currently fitted until next Tuesday, so what tips on checking the system out :)
S
sinbad1
You will need Red propane bottles
When you say you will not get to see whats fitted not sure what you mean ?
if you are buying a motorhome from a dealer and they are fitting the bottles for you then i would ask them to demonstrate all of the gas appliences to make sure they work.
Regards
43,348
49,546
i agree with sinbad,
red propane, preferably Calor bottles. (exchange 'em anywhere unlike some others)
the van may be fitted with a butane regulator, depends what the previous owner used, but they are only around ÂŁ7 for a propane bottle top regulator and are easy to fit.
it may have a bulkhead regulator which will mean changing the pigtail hose if its butane....not sure if you need to change the regulator as well. some one will know for sure.
having said all that you can use butane if you want but it doesnt work too well in cold weather.
43,348
49,546
just a suggestion......if you have to provide them try your local rubbish tip/recycling center.
the guys sometimes sell them for a couple of quid for the coffee fund.
a lot cheaper than going to a calor dealer and paying a large deposit which you will probably never get back unless you keep the reciept. and who keeps reciepts for years?
43,348
49,546
Best deal for 6kg bottles ........gas included
Regards
if you read the listing the guy doesnt know what he's got:RollEyes:
its obviously a 6kg but the listing staes a FULL 15KG :Doh:
think my last 15kg was ÂŁ24 exchange. wish i used enough to fit gaslows:winky:
Kon tiki
487
North Wales
Low Line
Have you tried your local Freecycle group Link Removed I asked for a small red propane bottle & somebody has a 3.6kg one they no longer need. Otherwise try your local rubbish/recycling center they usually have loads of these cylinders. Often you can exchange them for a different size depending on the dealer (some will some won't)
Don't know why you suggest Calor?? Flogas are cheaper & have free delivery Link Removed
S
sinbad1
Yep your right, thought this was the seller where i bought mine from :Doh:
This is the supplier based near brum no deposit required bottle + gas picked two up for my van when i first got it
Link Removed even cheaper
Regards
45eEver
267
Sinbad1, check the regulators (pressure reducing valves) that you will be fitting to the gas bottles.
You may wish to choose the bottle to fit the regulator.
If not, you will have to change regulators.
S
sinbad1
If you read the thread the link i gave was in response to the original poster
My system is fine and system checked for pressure and system leaks
Regards
45eEver
267
Sinbad! check what sort of regulators (pressure reducing valves) you have fitted to your motorhome.
Then get bottles to match the regulators you have.
Otherwize, you will need to buy new regulators, or adapters.
Sorry nI did not make my message clearer before.
S
sinbad1
?...........:Doh:
geoff1947
988
98
Plymouth
low profile
10 yrs
Surely if you are gettin it second hand or from a dealer you should get a bottle included and they must explain the system to you!! Don't pay till they do. I swop mine at the local Calor gas depot which is cheaper than shops or sites etc. Its ÂŁ18 for the new lightweight 6kg Calor Lite Propane cylinder which last for a good while if used sensibely. The Propane metal cylinders are quite heavy in comparrison and can be a struggle to get them in and out off the locker so check the access to the gas locker also!:thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
and around ÂŁ5 if you fill it yourself with an adapter.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
flogas may be cheaper but not available all over the country, calor is.
45eEver
267
Delwood33 check what sort of regulators (pressure reducing valves) you have fitted to your motorhome.
45eEver
267
Sorry about that Sinbad.
Thanks for drawing my attention to my error.
The message was for Delwood33.
dellwood33
dellwood33
878
Newcastle
italian crap
too long
So Red it is then. I have been shown the operation of the fridge, heater etc, but we did not open the gas locker. I now will check on Tuesday and query the gas and fittings if it is not red:Smile:
errpaul
538
83
Wiltshire
11 yrs
From my limited knowledge blue is butane, red is propane. Propane freezes at a much lower temperature than butane from what I'm told making it prefarable.
Also butane (blue) comes in 7kg rather than 6kg (although at my local calor retailer they are the same price making the butane slightly cheaper)
Anyway our MH was bought used from a dealer and it was fitted for butane, so we asked them to change it over as part of the deal. Also our's didn't actually come with a bottle (I guess the previous owner kept it when it was part exchanged), however, again we got a full bottle thrown in as part of the deal.
oldun
747
162
St Neots
VW Campervan
Since 2001
Both butane and propane FREEZE at temperature far far far below the atmospheric temperature so neither will ever freeze in normal use.
However liquid butane virtually stops giving off gas at about 6 degrees Celsius making it not very useful on cold days. In cold parts underneath the van gas may liquefy and cause a blockage even at temperatures above 6 Celsius. The actual process of evaporation inside the bottle will also cool down the bottle aggravating the process. lagging the bottle will not necessarily help as the evaporative cooling process occurs inside the bottle/
Propane continues to give off gas down to about -40 degrees Celsius making it OK for cold winter days.
