Garmin Error Message - Power cable not compatible
Discussion in 'GPS Navigation' started by Robert Clark, Apr 6, 2015.
  1. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,818
    12,940
    East Sussex
    Hi Guys
    Garmin Nuvi 3598
    Trying to charge and update my Garmin after a number of months of being unused
    When connecting is to my PC OR my plug in charger I get an error message
    "Power cable not compaitble - please use the cable supplied with your Garmin" (or words to that effect"
    The device then stops charging
    Have tried using the original Garmin cable but get the same error message
    Have reported the fault to Garmin online, but they won't respond for 3 working days, by which time I'm going away
    Any ideas would be appreciated
    Robert
  2. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    884
    666
    Warwickshire - sometimes - but not often
    Have you tried a reset on it. Mine locked up once & a reset fixed it.
  3. Robert Clark
    Jul 12, 2014
    6,818
    12,940
    East Sussex
    How do you reset it?
  4. gozomike
    Mar 16, 2010
    884
    666
    Mine has a small hole on the bottom, I just insert a straightened paper clip. The manual should show where it is.
    • Like it Like it x 1
  5. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,791
    2,217
    Scotland
    Hold the power key down for 10 seconds.
    Think this is the manual for it - 35x7 (albeit it says 3507 \ 8).
  6. Robert Clark
    Jul 12, 2014
    6,818
    12,940
    East Sussex
    Sadly no obvious holes
    As it's been switched off for 4 months I'm wondering if the battery is totally flat
    I've put it back on charge and switched it off. Hopefully when it's got some power in the battery it might perform correctly again
    Will look online for the reset function if this doesn't work
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    Dry cell batteries must be stored with at least some charge.
    Chances are, after a few months, your battery is damaged and wont take a charge.
    Or.....
    Try plugging in and just leave it for 24 hours regardless of error messages...it may be like some tomtom's and will accept a very small charge in the background until a set voltage is 'seen' by the charger and charging begins properly.
    Looks like you read my mind Robert
  8. gozomike
    Mar 16, 2010
    884
    666
    Could be, it will vary between models.
  9. Robert Clark
    Jul 12, 2014
    6,818
    12,940
    East Sussex
    Holding the power button did reset the device - thank you. But the fault still exists
    Will try charging in the van to see if this works
    Not desperate to connect to my PC - just want it working as we're going away in 7 days
  10. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,062
    12,415
    Plympton, Devon
    Some cables are for charging only, try a different cable.
  11. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    Just had a look for you......hold the power button for 10 seconds.
    Obviously this will only work when the battery has some power.
  12. Robert Clark
    Jul 12, 2014
    6,818
    12,940
    East Sussex
    Reset worked but fault still exists
    Will charge overnight - switched off, and see what tomorrow brings
  13. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    plug it into a mains supply adaptor of sufficient output amps.......it may need 1 or 2 amps to charge and some adaptors can be as low as 500ma and cant provide enough power to kick in the charge mode.
    I speak from tomtom experience.
  14. Gellyneck
    Jun 5, 2014
    1,791
    2,217
    Scotland
    Fingers crossed.
  15. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Phone them-number on website (y)
  16. Robert Clark
    Jul 12, 2014
    6,818
    12,940
    East Sussex
    Update....
    Left the unit on charge overnight, however got the same error message when I switched it on
    Connected the unit to my PC and found that I could browse the contents of the memory and the sd card, which was encouraging
    So I loaded Garmin Express and 'hey presto' it could see the unit, so immediately updated the firmware
    Having done that I got no error message so continued to update the maps too
    Not sure what the problem was, my suspicion is that the firmware was corrupted
    Thanks for all your help and suggestions guys
    Much appreciated !
    • Like it Like it x 2
  17. Gellyneck
    Jun 5, 2014
    1,791
    2,217
    Scotland
    Good news, Robert.
    Would surmise the same. Maybe a previous update failed to install fully \ properly?
