Garmin 760 lmt-d (1 Viewer)
Melvin
230
182
Norfolk
Coach built
On & off since 1974
Hope someone can help ,I'm not sure if I have set mine up correctly or its just the way it works. When I approach a town on an A road instead of directing me to follow the A road it starts to use the road names instead , seems to do this on the written description also .
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
My old Garmin does the same. The pronounciation of French and Spanish names is attrocious :)
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Ooer never noticed... What's up with that then?
Melvin
Melvin
230
182
Norfolk
Coach built
On & off since 1974
It' was new in Mach this year
Some Garmin models have a choice of voices - English/American/Male/Female and sometimes some voices use road numbers/names and others don't - a case of try the different voice settings and see which you like best.
Thankyou I will try that.
GJH
29,450
38,827
None, now sold
2006 to 2022
I think ours does the same but I wouldn't swear to it and can't say that I have noticed anything detrimental. Where there are street name signs, rather than road number signs, it can be easier to spot them in order to take (say) the correct turn.
Jan 3, 2008
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
I don't care whether it uses road numbers or street names as long as it gets me on the right road in the right direction. Actually mine uses a combination of both with is fine with me, I don't see a problem.
Melvin
Melvin
230
182
Norfolk
Coach built
On & off since 1974
I find it more annoying than a problem especially when using the smaller A & B roads that go through small towns that have oneway systems that have been cobbled together using the old roads.
The reason I posted was that I'm not very good with modern tech and thought I probably hadn't set it up correctly .
Jan 3, 2008
3,341
5,359
Looking
No, I think your set up is probably fine, its just the way it works, at least that's the way it works on mine. I think its because when you enter a town/village there are lots of different turnings and roads which may not have a number anyway so using street names is the only way of giving directions . For example my street does not have road number but is off of a road that does, so the instruction would be continue on the B1234, in 200 yards turn right into the avenue.
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
Makes no odds for us, as the wife constantly tries to override the sat-nav with her "superior" geographical knowledge. That's the same one who ended up in South Wales when she should have been in Shropshire :roflmto::roflmto:
Jul 29, 2013
9,071
18,566
Salisbury
Hymer B678DL A class
since 2011
I find it a pain as you very often can't see the road name as they are obscured by hedges etc or even not there but you get used to it eventually.
GJH
29,450
38,827
None, now sold
2006 to 2022
Names or numbers it doesn't really matter. Following the distance countdown/arrow to the junction indicates the correct one, especially with urban streets close together. Same with coming off roundabouts.
golly
2,006
69,657
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I prefer the road numbers as I always list the road numbers I want to use from an atlas so that I have a general idea of the route, and I don't trust the sat nav not to take me on a tiny little road just to save 100 yds:rolleyes:
scotjimland
2,353
10,223
A Woosh bang
Garmin Camper model won't 'normally ' do that ..
However... none of them know the road width.. the data base doesn't exist with road widths.. only classes ..
for example.. in Wales we were on A roads that were barely wide enough for two trucks to pass one aother.. and on one section.. we had to stop and reverse into a lay-by to allow a tractor to pass .. the road to our village is B class but wider than some of the A roads in Wales..
An A road can be narrow two lanes or a dual carriage way .. sat nav has no way of knowing.
Reactions: GJH
DJA
Mar 5, 2011
661
1,014
A
Since 2008
My Garmin 660LMT-d totally ignores a main A road locally and suggests 10 mile detours. If forced to to use it then it routes you through a parade of shops before directing you back to the turning it ignored. Wouldn't be so bad if it had a list of shopping it thinks I need to stop for.
Doug
Jul 29, 2013
9,071
18,566
Salisbury
since 2011
I wonder if anyone has discovered a sat nav that does work as we want without mystery tours if they have Ill get one(n)(y)
GJH
29,450
38,827
None, now sold
2006 to 2022
I suppose then nearest one can get is a Garmin used in conjunction with route planning on Basecamp to avoid roads one is uncomfortable with (or doesn't wish to shop on :D).
MicknPat
614
3,606
Touring UK
39ft American A class RV
Since Oct 2007
Can be quite funny
Melvin
Melvin
230
182
Norfolk
Coach built
On & off since 1974
Sorry for my ignorance , but what is base camp and what does it do. I don't have a PC or a Mack so if I need to download anything I have to visit a friend ,15 miles , or wait until I see my youngest son , 150 miles .
I only have an I pad that usually does everything I want.
scotjimland
2,353
10,223
A Woosh bang
basically you plan a route on Basecamp on your PC or Mac then load onto the Sat Nav.. don't believe that it's available for iPad
http://www.garmin.com/en-GB/shop/downloads/basecamp
I did a post on it..
Getting to grips with Basecamp
http://www.motorhomefun.co.uk/forum...g-to-grips-with-it.117985/page-2#post-1600184
Reactions: GJH
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Oh basecamp. ... one day ...
@Melvin you may need to update your sat nav at some stage. That would involve a PC.
GJH
29,450
38,827
None, now sold
2006 to 2022
Unfortunately you will never get the best out of a sat nav then. They are all designed for use in conjunction with a PC/Mac, even if just for map and software updates.
