Garage recommendations - South France (1 Viewer)
Beakster
67
234
Brighton
I'm new!
Can anyone recommend somewhere we can get our brakes looked at in the South of France, currently near Beziers and will be near Ales next week. Apparently pads were almost new before we left, done 2500 miles since. There's sometimes an awful grinding noise from off-side front wheel so assume it's a brake problem... Fiat 2.8 JTD
Aug 17, 2011
422
211
North East
Dethleffs T7057
since 2011
We had problems finding a garage when we were down that way and were told by normal garages to go to a camping car garage. In the end we just winged it and hoped for the best and got the van fixed in U.K. But for you that might not be easy! Good Luck.
We were told there's a camping car garage in Beizers though
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Any repair garage will do, as will any Feu Vert (sort of quickfit type chain). Google for branches near you.
Aug 18, 2014
23,786
133,732
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
could also be a stone trapped or even a wheel bearing starting to go
Beakster
Beakster
67
234
Brighton
I'm new!
Just had a look at the disc and the inner face is not as smooth as the other. I'm guessing to brake pad has worn down to the metal, sounds like that!
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
The new pads can operate on part of the old disc which will have a wear lip and/or corrosion its not uncommon and will generate a noise, if fitting pads only we grind back the disc so its clear from the pads, if you can see your discs then you may be able to see where the pads are contacting the corrosion/lip.
