G4 LED bulbs
Discussion in 'Tech/Mech General' started by lebesset, Aug 14, 2009.
  1. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    has anyone any experience of these bulbs ?
    as in so many motorhomes , we have under cupboard lights which are fitted with this size bulb ; unfortunately , although the halogen bulbs haven't faded , the eyes have , and reading is increasingly a problem
    more than one wattage of halogen G4 bulb is available it seems , but as you will all know , solar panels or not , electricity supplies are finite
    so LED sounds the way to go ...but question is what [ pun intended ] do I need ?
    I see LED's in the G4 sideways profile offered at 80/100/120/140 lumens ....how do these equate ?
    any feedback appreciated
  2. peter H
    peter H Funster Life Member
    Jan 18, 2008
    1,350
    662
    Neath, South Wales
    Hi there
    100 lumen is about equivalent light output to 5w halogen lamp, but the power consumption is about 0.3 watts.
    Basically more lumens brighter the output.
    Hope this helps.
    if sucsessful, post a comment as i guess lots of people in similar position.
    Peter
  3. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,656
    8,133
    Tropical Bar,Benidorm.
    We have replaced our halogen bulbs with LED's. We have fitted the warm white variety for general use, and have used the bright white variety in those lamps required for reading.
  4. hilldweller
    Dec 5, 2008
    27,240
    26,241
    Macclesfield
    Not that easy - I've replaced all our bulbs with LEDs but because of the different light pattern I had to alter the LEDs to get the best out of them. As plugged in the LED was so deep in the holder it was not efficient. I soldered on flying leads and glued the LED to the glass of the fitting, that made a good improvement. But even so probably a bit less bright that the tungsten bulb.
    I rejected bright white for warm white, I found the bright one too glaring but this may be a benefit for you.
    On the main ceiling fitting I replaced a reflector bulb with 3 LED modules to get a better spread of light. So, LEDs do work but maybe not just as a straight plug in.
    Mind you, in the last 2 years LEDs will have improved even further.
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,940
    I put one of these in the washroom of our van and find it brighter than the bulb it replaced.
    Also put some similar to this (except we used ones with 4 LEDs) in the spotlights and find they are great for reading.
    We used White rather than Warm White but that's purely personal preference.
    Best way is to get them at a show because the suppliers have display boards set up so that you can see the difference between different lamps.
    Graham
  6. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    32
    Cumbria, Lake district UK
    I replaced all the halogen bulbs in my van with LED's. The saving in consumption is staggering.
    I have a 100W crystalline solar panel on the roof, and within minutes of the sun coming out, even after a full evenings use of the lights, the panel reads a full 14.7v and zero consumption.
    When using the old halogens, it could take several hours of bright sunshine to replenish the battery.
    The bulbs I use are very, very reasonable - about the cheapest I've seen:
    MR16 Bulbs
