Fuses (2 Viewers)
johnp10
7,774
15,181
North Lincolnshire
8 years ish
I have a Bessacar E745.
The reading lights above the side seats have gone off. (Due to me, long story)
The hab wiring diagram shows a block of six fuses below the wardrobe. No probs, found those, but they dont seem to control these lights, all fuses intact.
The diagram shows a seventh fuse, not part of a block, which I cant find.
The diagram shows this as "EMC Lights".
Anyone know where this fuse is, and what does EMC stand for?
43,332
49,510
EMC is a lighting standard.
The test requirements of these standards include conducted RF emissions, insertion loss measurements, magnetic field and electric field emissions, radiated immunity, conducted RF and transient type immunity tests on power and signal cables as well as ESD (Electrostatic Discharge).
Examples of equipment that fall into the requirements of EN55015 & EN61547 are:
  • Energy Saving Bulbs
  • Lighting Ballasts
  • Lighting Converters
  • Fluorescent Tube Starting Devices
  • Dimmer switches
  • Light Fittings with active components (such as fluorescent fittings)
sorry, cant help with the fuse location :Sad:
have you checked the fuses with a multimeter....some cheap fuses may look OK but testing with a meter can prove otherwise.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Thanks John
(I think)
It's the fuse itself I cant find.
The diagram seems to have 4 lights on the absent fuse, which appears to be the culprit.
Everything else is working fine, just these bloody reading lights.
43,332
49,510
EMC = Electro-magnetic compatibility
lights which don't emit an electro-magnetic field....
i don't think we need worry unduly about that.
:winky::thumb:
43,332
49,510
Thanks John
(I think)
thats what i mean....remove the fuses you can find and stick a multimeter across them...it could be one of them. :thumb:
wiring diagrams don't always equate to the actual wiring method.
"Mmm!!! its easier for me if i do it this way instead of how its shown in the book"
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
I've moved them about, John, Keeping the right sizes of course, no change.
None of the six block fuses seem to control the readers.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
It'll be somewhere daft, John.
I thought daft but still couldnt find it.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Think like a daft Geordie and you'll sort it:roflmto::roflmto:
Tried that, BIll.
NOt daft enough, apparently.
Pappajohn: I've pulled all the others in turn, everything on the block of six has a function. Got to be the missing link.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
FOUND IT!
AS advised by Bill Tick59, | thought like a daft Geordie and looked where it shouldnt be.
A single 5a blade fuse (the culprit) lives behind the control unit.
This fuse only protects the reading lights.
Need to gently ease cables upwards to expose it.
Same for all Swift manufactured vans?
champers
4,224
8,486
Skegness, UK
Frankia i650 FD
Since March 09
Sorry only just seen his thread, we had the same prob on our E745 looking at the sink there is a panel above it and it was buried deep in the wiring there drove us crazy trying to find it, in fact it was Ash who finally discovered it there :thumb::thumb:
43,332
49,510
John, do you mean the reading downlights under the overhead cupboards in the lounge area?
in our kontiki they were all 20watt halogen bulbs....4 of 'em....and a further 2 over the dinette.
4 x 20watt = 6.6amps.......why would they fit a 5amp fuse ?
I'm wondering if its blown before and been replaced with too low rated fuse.
unless yours are 10watt bulbs of course :thumb:
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Yeah, thats it.
4 x 10 watt bulbs, John.
All the other "house" lights are on two separate 10a fused circuits.
All fuses are to strength as per the handbook.
Sorted now. Nearly did me head in.
