Fridge Power On Overnight Ferry. (1 Viewer)
Chipster
1,008
1,121
East Midlands
Getting there!
What do folks do with the fridge on overnight ferries? Is it ok on 12v for the trip. We have 2 95ah leisure batteries but not sure if this is allowed or the done thing. Thanks in advance!!
2,338
10,140
The 12v only works when your engine is running.. and you can't use gas on a ferry
Fill your fridge to capacity and it will be fine for an overnight trip.. if you have space, put pre frozen plastic bottles of water ..
Chris
21,056
278,903
10 years
We plugged ours in on the ferry at Easter on the way to Santander.
Just ask when you are loading and have your electric cable ready as well as your French conversion ( 2 pin) fitting.:thumb:
mikebeaches
5,395
8,601
Bristol
Rapido V68 Van Conversion
We just loaded the fridge up with everything well chilled and / or frozen (as appropriate) and it was fine on our trip to Santander. Same on the way back. :thumb:
Mike
13,083
101,459
Bolsover, Derbyshire
Hymer S800
not long enough
Now I know they might I would be trying for EHU
Much reduced chance of flat battery as well
Been there, v embarrassing :thumb:
oldun
747
162
St Neots
VW Campervan
Since 2001
I assume that you are talking about a three way fridge, 240V, 12V or gas. With this type of fridge I use to freeze plastic bottles full of milk and place ion fridge. It keeps the food cold for a long time (providing that you don't keep opening the fridge door) and the milk can be used later.
If you have a 12V only compressor fridge you can leave it on overnight with no problems whatsoever - assuming that you habitation battery has a good charge to start with.
Chipster
Chipster
1,008
1,121
East Midlands
Getting there!
Yes. It's a 12/240/Gas fridge. Thanks.
