If I am on a site where it is not possible to level the unit what do I do about the fridge. I have heard it is not good for them to be working when not levelled, but how long will they be alright ie overnight, a couple of days?
The fridge in my MH is a tilt tolerant fridge, our drive is sloping and it works ok.
the design of the lpg fridges means that if the small flame isnt discharging heat directly up the chimney, they wont work as well if at all. the latest fridges are better but in older vans it only took a few degrees from level to fail
they work better on 240v rather than gas if out of level because the heating elements are touching the heat exchanger
to see why the flame being out of level is critical. try lighting a tealight candle and hold a piece of pipe above. when the pipe is vertical above the flame, more heat is convected from the top than if at an angle. also the flue pipe will soot up on one side
Mine is a 2011 Damon Daybreak - is it likely the fridge is slope tolerant do you think?
