Ford transit - extra batteries
Discussion in 'Motorhome Chat' started by cellojane, Apr 29, 2010.
  1. cellojane
    cellojane Read Only Funster
    Oct 6, 2009
    33
    Leicester
    Forgive me if this is obvious!:Blush:
    In case it's of interest to others I had a chat with the friendly AA man this week and he informed me that there is space for 2 batteries under each seat in the transit cab - the mounting brackets for two batteries under one seat is about £15 from Ford. We're thinking of an extra leisure battery and didn't realise there was space right next to the exsisting one so were going to put it in the cupboard next door. Maybe others will feel like having one fitted if they realise how easy it is.
    jane
  2. hallii
    hallii Read Only Funster
    Apr 23, 2010
    61
    Worcestershire
    Hello Jane, mine has already got two leisure batteries but not both under the seat, one is in a cupboard.
    Just a point, you should install two new batteries as the older one will not have the same capacity as the new one, this is important for efficient charging and battery life.
    You might find that you can fit a bigger capacity battery (which will be bigger in size as well) in place of the one you have.
    Hallii
  3. activecampers
    activecampers Read Only Funster
    Jul 28, 2008
    420
    102
    Heathrow
    Yep
    Easy to get 2x 100AH batteries under each seat. No need for brackets either as, under the pax seat, its a tight fit and they won't move. I've just used a ratchet-strap (poundland probably) and they can't move a mm.
    There is also existing plasitc covered ducting between the seats (need to pull up all carpet/foam etc) so you can safely run thick cable between them (though protect cable on seat box entry). Also there is ducting towards the dash so if you want to run habitation power to dash (for instance for a radio mod and/or a habitation AUX socket) you can safely.
    (Transit mk6 at least!)
    Elecsol 100 AH fit fine and the 110 *may*. Height is critical as the 100AHs only just fit (with my swivel plate fitted at least)
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,013
    5,319
    Wirral
    My new HYmer Exsis on the FWD Tranny has an 85Ah leisure battery and halogen lights need to change to leds and a larger battery. Do you know if I can install 100 Ah batteries in this model?
  5. Bulletguy
    Bulletguy Read Only Funster
    Feb 7, 2008
    2,051
    6
    Cheshire/Staffs
    There is also room to easily fit an 85ah on top of the n/s inner wheel arch and if it's a non-turbo 2.5 you will even have room for a 110ah.
    If you fit a battery anywhere inside, remember to vent it!
