'Floe' water drainage advice please!
Discussion in 'Tech/Mech General' started by scammellmanswife, Jan 12, 2015.
  1. scammellmanswife
    scammellmanswife Funster
    Dec 4, 2012
    667
    625
    leicester
    Maybe someone can advise me! Does anyone use this method to clear their pipes of water when draining down. Is it easy for a non techie to install and use and is it worth it or do you use another method. If this has been discussed before I apologise. I don't seem to be able to find the search button on this new site maybe someone can help with that too.
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,127
    1,866
    London
  3. scammellmanswife
    Dec 4, 2012
    667
    625
    leicester
    Thanks mike will read through that lot later then. So how did u get the info what buttons do I push lol
  4. scammellmanswife
    Dec 4, 2012
    667
    625
    leicester
    Thanks mike I will read through that lot a bit later. So how did you get to the relevant search tab. I used to be able to do it on the old site but my aged brain cells are not working on here. :(
  5. houdini
    houdini Funster
    Oct 20, 2014
    729
    2,700
    Hampshire
    Hiya - Search is up top right hand side above your avatar, hope that helps. :)
  6. scammellmanswife
    Dec 4, 2012
    667
    625
    leicester
    I told you the brain cells wern't working I have even duplicated my reply !!!:(
  7. scammellmanswife
    Dec 4, 2012
    667
    625
    leicester
    No cant see it !!
  8. MikeD
    MikeD Funster
    Dec 21, 2011
    2,127
    1,866
    London
    Top right hand corner of the screen
    Comfort insurance Advert
    Just below that is a dark blue line - your name (scammellmanswif), Inbox and Alerts.
    Just below that wrote quite fine/faint is the search facility. (y)
  9. scammellmanswife
    Dec 4, 2012
    667
    625
    leicester
    Thanks mike and houdini I have now found it via my super slooooooow laptop which I only use when forced to. However it does not appear on my android phone so I will know next time.
  10. icantremember
    icantremember Funster
    Sep 2, 2010
    5,335
    7,459
    Nr Watton in Norfolk
    I have fitted the Floe system .... very simple job.
    I pressurise mine with a Ring digital tyre inflater and it certainly gets more water out of the pipes and saves having to blow into the taps.
    They are a bit pricy but are sometimes available at reduced prices.
    Of course you could make up your own as done by @Techno100.
  11. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,083
    Leeds the one up North
    On android it is the magnifying glass below the ALERT
    [​IMG]
  12. scammellmanswife
    Dec 4, 2012
    667
    625
    leicester
    IMG_20150112_130907200.jpg Aha all is revealed thankyou @techno I have just looked up your bit about the floe and it is very helpful. My pipe system looks a bit cluttered around the pump do you think it can be done
  13. Techno
    Jul 28, 2010
    14,138
    15,083
    • Like Like x 1
  14. musson
    musson Funster
    Dec 25, 2013
    402
    140
    grantham
    Hi fitted one took about 30mins (cost around £30 delivered on ebay) I did buy some pipes cutters of ebay about 2.50 to make sure cuts were square and easier than a stanley knife.
    I have to say i was surprised how much water came out of the sink tap,also the boiler
    • Like Like x 1
  15. Techno
    Jul 28, 2010
    14,138
    15,083
    Used my DIY one today and left the system in storage with 20psi in it.
    Should still be there until I let it out (y)
    • Like Like x 1
