Flat battery (1 Viewer)
Jan 16, 2014
790
1,916
Harleston, Harleston, Norfolk, UK
C Class, Autotrail Scout
Oct, 2013
Went out this morning to give the MH its monthly run and found the battery was completely flat. Voltage measurement across the disconnected battery terminals 0.8v, checked the multimeter against a known good battery and it checked OK.
Measured the resistance across the battery leads, dead short, so the question is, what could be in circuit with the ignition switched off? :Doh:
Merc Autotrail scout 2002 - sprinter
MikeD
3,936
3,697
London
IH PVC
A light on maybe?
I have no expertise but sounds like a light is on somewhere? :thumb::thumb:
icantremember
8,338
17,560
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Went out this morning to give the MH its monthly run and found the battery was completely flat. Voltage measurement across the disconnected battery terminals [HI]0.8v[/HI], checked the multimeter against a known good battery and it checked OK.
That is DEAD and will probably not be retrievable.
Probably Dawn left something switched on.:Doh:
There are many things that help to drain your batteries such as alarms, clock, radio.
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
Hi. I agree with the comments Brian has made above regarding the battery state and possible items causing a drain on it. I would connect a good battery with an ammeter in circuit and then see what drain there is and track it from there.
Mike
Oct 20, 2013
5,299
13,217
South Norfolk
Yes
[HI]Probably Dawn left something switched on[/HI].:Doh:
Not everything is my fault :cry:
Besides I just tried to use the hoover without plugging it in - I don't 'do' electrics
rikfos
315
199
hereford
Maybe the alarm or immobiliser has run the battery down.
Have the battery checked.
I have a small solar panel that fits on to the windscreen and this plugs in to a live 12v socket
and costs about £9, this tops up the vehicle battery.
gozomike
Funster Life Member
1,001
863
Since August 2008
It could just be a faulty battery.
A couple of weeks ago a friend came out to Gozo, he had used his truck for a couple of days and then again the next morning. He went back an hour or so later and it would not start. I went down with my jump leads, it would not start. I tried running mine with the leads connected for a while and the hand throttle giving a fast tickover – still no go (both vehicles are Toyota Hilux pickups) . The battery volts were reading around 10. We tried to charge the battery on the bench for at least 2 hours and it would not take anything so we took it back to the garage which had supplied it. He checked it and just gave us a new one.:thumb: I recon it was around 18 months old.
It is not common for a battery to fail like this but I have known it before.
Mike B
Jan 16, 2014
790
1,916
Oct, 2013
Fitted another battery and found DAWN had left the radio on (or someone other than me had). :Blush: those dogs have got a lot to answer for.
Unlike a normal vehicle, when you turn the ignition off the radio is still in circuit.
One new battery coming up.
Thanks for all your help.
Oct 20, 2013
5,299
13,217
South Norfolk
Yes
Fitted another battery and found DAWN had left the radio on (or[HI] someone other than me had[/HI]). :Blush: those dogs have got a lot to answer for.
I knew there was someone else :cry:
Heyupluv
3,862
1,593
France,
touring many years..42+
I would say it is the immobiliser..and anything else unknown that may be running in the backgrond..this use to happen on my last Fiat 130 multijet:Doh:
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Look on the bright side. Nothing wrong with the MHF. Result.:thumb:
Reasonable charger available from lidl at the moment that can be used to recover over discharged batteries (maybe)
Had an issue with a solar panel lead that took a bit of tracking down. Couldn't understand why the batteries went flat with a panel fitted whilst in winter storage. Found a very unhealthy plug and socket that was the cause.
Cheers:Smile:
