Flat battery (2 Viewers)
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Im asking this for a friend of a friend who is parked up at my friends alongside me. I have suggested joining MHF but as they need help to learn what a post is I shall ask the Q.
They have a Mh around 1998, drove through Ireland and had a flat battery one morning. A garage replaced both alternator and fan belt. They drove up from Cairnryan to Glasgow today. After stopping half hr on arrival the battery was flat.
Being female the only info ive learned is from all you guys...I put voltage meter on battery without engine running..11.78. But when engine started it only showed 11.66 which is even less and not more.
Any suggestions? Im guessing duff battery.
23,836
72,511
How long after you started the engine did you wait before checking the voltage, and how long did you check it for ?
If you started it and checked it straight away and only for a few seconds the battery will have taken a big hit to start the lump and may well have come up a lot higher as time went by..
Restart it and let it run for a few minutes and check again.
If it is still low then the alternator they had fitted is duff.
Also ask how old the battery is.
There is often a reason alternators fail.. a really old battery ! The charging system will try and bring a duff battery up to spec and because it ( the battery ) is well past it, it will never reach a charged state, so the system will keep on working flat out to try and bring the battery up.. a nasty vicious circle !
43,332
49,505
Are they sure the alternator was renewed or did they just pay for something they never got.
If it's only showing 11.66v with the engine running it sounds like the alternator has failed....or the belt has snapped/come off.
If there is no charge at all, the battery will show a lower voltage when running as the starter has just taken a little bit more out plus any electrics needed to run the engine....electric lift pump, fuel solenoid etc.
Volts out, no means of putting volts back in.
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Ive retreated back to my MH now...Big brother on tv and its getting dusky. Will try again in the morning if it starts. I did ask if there was a way they could divert the ehu to charge starter battery but they dont know.
They have now tried to get on MHF and only now do I appreciate how everyone is not pc savvy. I know where my 2mor is going ..
43,332
49,505
Not like you John.....
The alternator will output at least 13.8v as soon as the engine is started regardless of battery state.
19,368
30,326
At 1998 could it be an externally regulated alternator and possibly the problem was never the alternator.
It could be a job for somebody a bit auto elec techy.
andy63
4,672
15,018
south shields
since 1990
Was chatting to Sandra and the lad earlier and I asked that question but suspect even at that age the alternator will have the rectifier and regulator built in..
I was wondering if the battery was bad a failed cell for eg could that be the reason for the voltage appearing so low even with the engine running...
Mentioned that he could check the earth lead off the battery...
As well ..
The red light has been on on the dash and remains on when the engine is running rather dim but still visibly glowing... which suggests a charging fault but the alternator and belt are new..
Hope you don't mind me butting in on your thread Sandra. ..
Andy
19,368
30,326
If the red light is on the alternator is not generating a voltage higher than the battery, I think.
andy63
4,672
15,018
south shields
since 1990
So can a failed battery cause the alternator to show a low voltage ???
Could check between battery positive and alternator output to see if there is a volt drop there ie bad connection and similarly the negative battery terminal and alternator body for volt drop...
But not sure if those conditions could prevent a normal charging voltage from alternator..
Andy
19,368
30,326
Never heard of one of those....except recent vehicles with 'smart charging' controlled by the ECU.
Only thing with an external regulator was a dynamo.
17,635
43,358
double check the charge wire hasnt fallen off the new alternator
23,836
72,511
Nooo.. it SHOULD output 13.8 volts but if there is a short between plates it will be held down to maybe 12.4 !
Having said that if the charge light is glowing then that would indicate the alternator is simply not slinging enough juice up the rope to the battery .. so almost def a duff alternator..
Just a though though.. If you have any jump leads put one between the battery -ve and the engine block.
A poorly earthed engine can cause the same issue, and as it is a rare fault the garage that fitted the belt and genny might have easily missed it.. or indeed left the earth strip off when fitting the alternator !
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I wouldnt know where to look. :eek: and I have a sore back so I have just passed on all your great info. Battery does look as if its not been off in a long time but man said battery was good as it was checked when alternator was replaced. He has the old alternator.
He did ask if he got stuck again could he use his leisure battery to start his vehicle with jump leads. I said yes but he would ruin his leisure battery if he done it too often...Did I get that right:sick:
andy63
4,672
15,018
south shields
since 1990
Without knowing what he was using as a leisure battery that's hard to answer but I'd have said the same :)..
I used to connect jump leads from my leisure to the start battery on my fist van as a matter of course on a cold morning... It always worked fine (y)
19,368
30,326
I imagine a get you home bodge especially if he has solar would be leisure batteries positive to cab battery positive with light cable and a suitable fuse, pull the fuse to start and then replace once running just to keep the engine services running.
