Fix&Go Puncture compressor
Discussion in 'Chausson' started by chausson15, Jun 29, 2010.
Has anyone else experience of using the Fix&Go kits
  1. How do you connect it to the valve without losing all the air?
    0 vote(s)
    0.0%
  2. Any suggestions as the best place to lit a spare wheel to a Chausson Flash02 ?
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. chausson15
    chausson15 Read Only Funster
    Jun 17, 2010
    5
    Southampton
    After reading several of your very interesting forums I took the advice of a subscriber and inspected the compressor and canister that is supposed to be of assistance for punctures.
    The first thing I did was to inadvertently turn the switch to the wrong symbol and get smothered in the sealant. The second problem I had was to locate a replacement canister, after a great deal of searching including the main dealerships I found one at the ever helpful Essanjay in Poole tel 01202683608. The third problem was when I attempted to screw the brass nut to the valve, it is a round knurled nut that screws to the valve but there is no room for big fingers to twist it onto the thread quick enough to stop air escaping from the tyre.
    Apart from mounting a spare wheel somewhere or fitting extensions to the existing valves have any other members had similar experiences?http://www.motorhomefun.co.uk/images/smilies/angry.gif:Sad::Sad::Wacko::Wacko:
  2. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    I had mine puncture sealed, cost about £80.00 to have done not worth trying it diy. pete :thumb::thumb:
  3. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    we use oko you get it in farm industry type shops put it through the valve then pump up .works a treat for off road ing .i used to use it in the truck have known it go in to a tyre with 11 punctures and still drive home from spain. costs about 9 quid for 2 wheels. its like green slime. tyre fitters hate you if you dont tell them when the tyre is due for change.
