- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
And I get nowt either. I tried the £79 offer and got answered with £82
Make that 101....I fitted 2x100 watt mono panels on the Camper last saturday along with the MPPT controlle recommended by you....cheers!So have at least 100 others Harry
Hi AutowbarsDo you know what the difference between a MMPT controller and a PWM is please?
I would say between 25% and 30% extra power from the MPPT, I did a back to back test starting with a standard Morningstar PWM and then a Votronic MPPT.Do you know what the difference between a MMPT controller and a PWM is please?
Not true, you can fit any dual output regulator or a single output one with a split charge solar relay.You also need to consider your control unit if you want to attach direct to it - our Schaudt one could only accept either a LR1218 PWM or a LRM1218 MPPT, the latter being a lot more expensive - as much as £100 more than the standard PWM one which can be bought for approx £70-£80. In this situation I'd go for a second solar panel rather than an MPPT controller ... why? Apart from the fact that I'd get more 'power' input for my outlay, if one panel gives up the ghost I can soon rig it so I just use the one, but if the controller goes poof I've got no power at all plus an expensive controller to buy again (not as easy to get hold of as the LR1218 one either).
Fitted Andy's recomended one to a EBL29 (newer version of 99) with a solar split charge relay feeding the starter battery solar connection on the EBL.Has anyone fitted one of Andy's recommendations to a Hymer with a Schaudt EBL99?
Do they have a gel setting?
Malcolm
They want £84 now because of the week pound they sayNot true, you can fit any dual output regulator or a single output one with a split charge solar relay.
It has Gel & AGM settiings.
Have been very impressed with this regulator, in thick cloud at the top of a mountain 20yds visability still getting 25 watts out of it.
@Techno got my 25 amp one for £78.
