Fitting own solar panel,???? (1 Viewer)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
I used on Andy's recommendation the same regulator and was so pleased I did. In June I changed over to the Victron one with bluetooth and whilst it's very good pound for pound the one Andy uses is just as good.
Minxy
32,624
66,461
E Yorks
Carthago Compactline
You also need to consider your control unit if you want to attach direct to it - our Schaudt one could only accept either a LR1218 PWM or a LRM1218 MPPT, the latter being a lot more expensive - as much as £100 more than the standard PWM one which can be bought for approx £70-£80. In this situation I'd go for a second solar panel rather than an MPPT controller ... why? Apart from the fact that I'd get more 'power' input for my outlay, if one panel gives up the ghost I can soon rig it so I just use the one, but if the controller goes poof I've got no power at all plus an expensive controller to buy again (not as easy to get hold of as the LR1218 one either).
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Do you know what the difference between a MMPT controller and a PWM is please?
Hi Autowbars
I'm sorry I don’t know the difference but I was told by Eddie from Vanbitz at the Newbury Show they fit the MMPT and the one they recommend is a Victron controller apparently they had done some tests and found the efficiency of these controllers outperformed the other ones “I’m not sure which other ones they meant” but having said that Eddie is very knowledgeable and I would always trust his advice.
This is the type he was recommending not sure if this was the exact model as I expect they have a few models available.
http://store.meadotech.com/?gclid=C...4V-10A-10A-Solar-Charge-Controller/p/52182781
Hope this helps.
Best Wishes Tony
funflair
19,305
30,073
Guisborough
MORELO palace
since 2012
I would say between 25% and 30% extra power from the MPPT, I did a back to back test starting with a standard Morningstar PWM and then a Votronic MPPT.
We also have a Votronic MPPT controller with AES control that uses any spare solar power to run your fridge on 12volts once your batteries are fully charged, they are not the cheapest controller at about £140 for the 250 watt model but you do save a little bit on gas when the sun is shining and depending how many panels you have.
It was also important to me that the controller had settings for Gel batteries as that is what we have fitted and they require a different charge regime to straight lead acid.
Martin
Sep 3, 2009
1,532
6,275
NW Surrey
LHD Hymer exsis-i
Has anyone fitted one of Andy's recommendations to a Hymer with a Schaudt EBL99?
Do they have a gel setting?
Malcolm
Lenny HB
53,321
149,532
On the coast in West Sussex
Hymer B678 DL
Not true, you can fit any dual output regulator or a single output one with a split charge solar relay.
Malcolm
Fitted Andy's recomended one to a EBL29 (newer version of 99) with a solar split charge relay feeding the starter battery solar connection on the EBL.
It has Gel & AGM settiings.
Have been very impressed with this regulator, in thick cloud at the top of a mountain 20yds visability still getting 25 watts out of it.
@Techno got my 25 amp one for £78.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
They want £84 now because of the week pound they say :mad:
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
Thinks I will,get Eddie to supply and fit, later in year before heading off to sunnier climes for a bit.
We tend to tour around so batteries usually charged, stop on sites maybe every 3/4 days to top up water, empty the gloop etc.
Thanks all for the replies, but to be honest more confused now than ever.
Don't want to buy a crap DIY kit and be in happy with it when We may need it.
