Fitting outside shower (1 Viewer)
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
Just fitting an outside shower in the m/h. The bullfinch unit has fittings for push fit connectors, the water system in the m/h uses 12mm bore flexible pipe. Any one know if you can get a 15mm push fit to 12mm tail.
I can get a push fit tap connector and then use a 1/2" male to 12mm tail but would like a one piece option is poss.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Broken Link Removed
Broken Link Removed
Broken Link Removed
:Smile: terry
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
Always wondered about fitting something like this for dog and/or sailing gear washing.....
andyman
Sep 23, 2007
1,710
1,970
Leicestershire
Broken Link Removed
Broken Link Removed
Broken Link Removed
:Smile: terry
Not what i need, i want 15mm push fit and a 12mm hose tail for the flexible pipe. The flexible pipe will need to be fixed with a jubilee clip.
TheBig1
17,630
43,310
3/8 tail for pipe to 12mm tail, then a 15mm-12mm reducer. neat and quick
Broken Link Removed
TheBig1
17,630
43,310
they dont make one that i know of. have always fitted them with a pushfit and a converter. neater than a tap connector as these are threaded and larger. the beauty of using the pushfit connector is it is easy to disconnect without messing with the jubilee clip and they can rotate and still remain waterproof. excellent with a leisure vehicle as it allows for pipes vibrating when travelling
Minxy
32,656
66,564
E Yorks
Carthago Compactline
Something like this might be more suitable as you can use it wherever you want, rather than have to be up close to the MH:
12v portable shower
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi and good morning :Smile: how about this one then ? Broken Link Removed
I think I have one so can see what a hose will fit like ?-if you use the first links you can go up from 12mm to 15 mm (half ins) then use a couple of ins of copper pipe on to your proper shower fitting bits from a builders merchant- think outside of the box ::bigsmile::winky:
terry
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
HI AGAIN I HAVE JUST TRIED THE ABOVE AND ALTHOUGH SMOOTH IT FITS THE VAN TYPE hose perfect :thumb: but I also tried half ins pipe onto a brass half ins compression fitting then onto shower head and that is even better see att pic PLUS YOU COULD EASY ATTACH A INLINE TAP which to turn on and off laving it all piped up permanently without the worry of a jub clip on smooth pipe :thumb:
terry
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Can you not use the standard shower fitted and hang it out the window-
andyman
Sep 23, 2007
1,710
1,970
Leicestershire
Looks like I have to accept 2 fittings. 2 fittings means 2 more joints = 2 more potential leaks.
May try to mod the tails on the shower.
andyman
Sep 23, 2007
1,710
1,970
Leicestershire
Found one, from CAK tanks
Oct 2, 2011
864
571
Scotland
Since 2011
If I fit an outside shower point , what is the best way to fit a shower hook. SWMBO likes her towel close. I will still shower inside.......
Minxy
32,656
66,564
E Yorks
You'll need a hook for the towel, a soap holder and a shower head holder!
:thumb:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
We have an external shower (standard item), and in the 5 years we've had the MH it's never been used. I find the watering can the easiest for washing off the dog.
