Fitting new 13 amp socket (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
I want to create a new power point to allow me to move the TV in our Autotrail Tracker SE. I am going to situate it on the side of the wardrobe with suitable bracing pieces on the interior to take the weight of the TV bracket and set itself. The new socket would only be about 1.5 metres from the Sargent unit but I'm not sure which circuit breaker to wire it into. The existing one that serves the other sockets? I can't see any room to add another one. Anyone done this? Advice would be appreciated. Many thanks, Jerry
Jan 26, 2010
577
1,493
Conwy, North Wales
Relay self build
Hi Jerry
I wired new 12v and 230v sockets into my Sargent unit. If you go onto their website and look for the wiring diagrams for your particular unit, you will probably be able to identify a spare wiring point. I had to get some of the multi block connectors that go into the PSU but Sargent were very helpful over the phone with getting the right ones.
Martin
PP Bear
7,807
28,782
Kent, UK
Auto Trail Dakota SE
Hi Jerry
I added 2 new 230v sockets into my Autotrail Dakota :)
Located under both seats and the bed are black covers that are there to add existing sockets as required. Took the covers off and there were the quick release coupling, that allowed me to simply extend as far as I needed and wired into my sockets, perfect :clap:
I intend to fit a 3rd very soon now that the socket has arrived from eBay (y)
Have a look and see if there are any in your Autotrail as it may be an easier job for you :)
Good luck ::bigsmile:
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
found a box marked addition 13amp supply under one bed with a plastic socket on the end. I'll talk to Sargent to find an appropriat mate for it. Nothing on the other side but the water heater fused switch. Any reason why I shouldn't tap a 13amp supply from that? Water heater plust tv are still not enough to trip the RCD surely? Any thoughts?
PP Bear
7,807
28,782
Kent, UK
I'd use the addition 13amp supply. While you may find that you don't trip the supply, it's really not worth the risk :whew:
There's no saying that you'll not end up wanting to draw a greater supply from the extended socket at a later date, or someone else will, once you eventually sell your motorhome on :wait:
Its easy to extend and install the new socket :roflmto:
Just my thoughts on the electrical circuit ::bigsmile:
Good luck with whatever you decide to do ::bigsmile:
PP Bear
7,807
28,782
Kent, UK
I use these as they're identical to the ones already fitted :)
Broken Link Removed
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
As long as u use 2.5 flex cable no problem as it protected by 13A fuse / probably 16A mcb(breaker)
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
I recently added a socket in my Autotrail Apache using identical socket to those already fitted,see link for CBE socket example, you can get whatever color surround trim is required to suit. Mine is champagne trim.
http://pages.ebay.com/link/?nav=item.view&id=291151602573&alt=web
I took a spur off the rear of a nearby socket that was in the ring main, using 3 core 1.5mm flex. You must use flex in caravan/motorhome, not twin&earth as in domestic installations due to movement and vibrations.
