But not the inbuilt on/off switch....a separate switch big enough to take the current.Hi hilldweller
What I take it are saying if not in use, switch at the inverter?
colyboy
Did you fit a fuse? That's the minimum protection but an isolating switch is extra protection and (some) inverters still take a current when they are switched "off".Ive always only switched off on the inverter. Never had a problem and never had a mega large wattage switch on the DC input side.
Must be a very small inverter to take a 15A fuseIn installed my inverter within two feet of the batteries with a lead from them to a battery isolator switch then to the inverter protected by a 15 amp fuse . From the inverter I ran a cable along the chassis to the front of the van to power a double socket. Works fine and I can isolate the batteries if I wish when not on EHU and not driving for a while.
Sounds perfect to me.
Just remember they can be a constant drain so connecting via heavy duty switch so you can isolate it when parked up is a good idea.
I was thinking of fitting it in the garage near the battery,
A 1000w inverter can draw over 80A DC
Why the need for a heavy duty switch? The inbuilt switch or the remote types that plug in switch off the power totally on mine so why complicate it and add extra cost?
Mine is a sunshine solar unit and there is no drain at all. I suppose different brands use different systems to shut down.Because even when switched off there is still a drain, albeit small, on the batteries if it's still connected. At least that's what the instructions on mine say and they also recommend an isolator.
Ditto sunshine solar unit no drain if switched off.Mine is a sunshine solar unit and there is no drain at all. I suppose different brands use different systems to shut down.
My inverter has a remote on off switch discreetly located on the sofa it is fitted into
Yes, your quite right the fuse is way over 15 although I am not in a position to check at the moment. Perhaps you or someone might suggest a suitable size for a 1000 inverter
I have used similar to this but using a 80 or 100amp blade fuse-
http://www.ebay.co.uk/itm/1-Heavy-D...471730?hash=item5b25feae72:g:0isAAOSwOVpXWo3W
I hope you've proved that with a meter. Any remote controlled and switched with a piddling little switch may have a standby drain, it might be small but if parked up over the winter it can still flatten your battery.
Same with a TV, I have an in-line switch in the TV power feed to kill the standby current.
A bit of current here, at there and then "can anyone tell me which leisure battery to buy this one is rubbish".
And that type is the one that will have a small standby current to monitor the push button.
I do not understand why you keep saying there has to be a standby current monitoring the switch (not a push button on mine).
I only use Fluke meters (that are calibrated for work) so there is no doubt regarding results.I don't think I've said "has to be" rather might be. It's all down to the designer.
OK, just spotted "will have" on one post, so prove me wrong.
As a matter of interest what resolution was the ammeter you used to said NO current ?
I'm impressed, we can assume under 1mA then. They have a circuit capable of gulping hundreds of amps and switched it off with no leakage. Top design.
Name it for the sake of other FUNsters.
