Emmit
Me and SWMBO are currently enjoying a long trip, (Well, it is for us!) in Portugal, and, as a result of being away for a protracted period we have identified 'stuff' that needs doing to the 'van.
We have a pre X250 Hobby which has a bathroom right across the rear.
However, instead of a roof light, it has a window, quite low down on the rear wall, and as a result, we are getting quite a build up of condensation in the room when abluting which affects the wardrobe that is also in the room.
Having identified the problem we have discovered that Fiamma make a small roof-light that would fit even allowing for the cross beam and ladder fitted to the roof.
Just so that I am forearmed with any potential prat falls before I start, can anyone tell me how thick??? the average 'van is in terms of the gap between the inside skin, which is covered in a quite pleasing lateral quilting and the outside roof which seems to be built of kryptonite .
I assume I will have to fill this void with a suitable batten (Upvc?). The actual roof-light clamps together (inside and outside) and it states you don't have to screw either onto the roof. I assume there will be a dose of Sikaflex applied to the exterior part of the roof-light.
So, there you have it. Other than measuring umpteen times before switching cutting gear on, any comments gratefully received.
Footnote from SWMBO: Could any Funster recommend a Co. to perform this procedure. (You can tell how much she trusts me,) Eh?
