First Motorhome! B584 (1 Viewer)
scottie58
60
18
berks
Picking up our first motorhome - a 2000 Hymer B584 on sat morning! I intend fitting a second leisure battery, anyone know where it should fit? Not had a chance yet to properly investigate the van. Can't wait:Smile:
43,331
49,467
hi scotty,
try to fit the second battery as close as possible to the original.
use heavy cables, at least as big as the cables fitted now, to interconnect (+ to + and - to -) and fit a fuse (30amp should do) at BOTH ends of the LIVE connecting wire as close to the battery as you can.
the further away the new battery is from the original, the bigger the cable needed.
lebesset
760
can't imagine having less than 2 big batteries in my 584....one under each front seat
as someone said ..nice big thick cables
Manouche
135
Southsea
20 years
Hi Scottie,
Welcome.
We also have a 2000 B584, not a bad choice of van,:Smile:
Our two leisure batteries are under the front seats.
Anytime you want to compare notes.......
Good luck
S
scottie58
60
18
berks
Had our first night away in the New Forest - great! Off this sat for 4 nights in Exmoor. Since i last posted i have had a look at the leisure battery - appears to be the original 75ah one. What size batteries have you guys fitted, and lead acid (cheapish) or Gel type? Being in the interior i would assume gel as they are sealed and give off no fumes etc?
I have also fitted 6 LED lights - much improved light and consume much less power. Looking forward to spending a few days in it to work out where to store all our bits.
I have also made an external screen from some old silver backed bubble wrap style insulation as no time to investigate / purchase "proper" screen covers. The condensation on the inside of the front screen after our first night has made me realise we definitely need one if we are going to use the van over the winter. Any prefrences - Silverscreen or Taylormade, plus what do they cost?
thanks for all the info:thumb:
lebesset
760
the two biggest batteries you can get in ...I guess the 75 is small enough to slide in without removing the seats which you won't do with a decent sized one
personally I use standard lead acid that you can top up once a year or more in a hot climate..ok , a hastle to take out the seats but never mind ; having opened up some of the so called maintenance free at the end of their useful life and found them with exposed plates , I have no confidence in THEM; have discussed them with an AA man of advance years he said that the AC Delco ones actually work and that some of the japanese cars use a copy of them
gel ? rip off and not required
don't forget to set your charger block to the correct battery type
which engine do you have ...the code should be on the rocker cover
chrisboyo
1,317
818
Newport South Wales
Autosleepers Sussex Duo
5 + 30 years a tugger
We have a B584 and love it !
2 75amp batteries with an 800 solar panal do us fine using tv ect
Had a month away in may with no hookup no prob
584 Use it , Love it
Chrisboyo
hogan
204
Valencia,Spain
Hi we have a B574
2 110 amp batts no solar panel most camping done in the winter, all wild camping no probs so far.:Smile:
lebesset
760
didn't think they made the 584 with the jtd in 2000 , thought it had the older engine if it was a 2.8 , the idTD ; isn't there a code on the rocker cover ...or haven't you found out how to take the bonnet off yet :roflmto:
Carol
14,051
112,117
North Wales.
Glad you are enjoying your 584, we also have the 584 2000 model it is a 2.8TD. When we bought it had the original gel battery with it but be bought 130Ah gel battery a couple of years ago thought 1 large one instead to 2 smaller, this together with our 85w Solar Panel which keeps us going without hook up with no trouble. We have had the van for 4 years now and absoulutly love it. Carol.
