First ferry trip (1 Viewer)
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
The fridge will be fine turned off overnight but make sure everything is nice and cold in there before the trip. We typically turn ours on the day before, then load it on the day. For the long ferry to Spain a frozen meal and/or a bottle of frozen milk put in the main compartment keeps everything cool - though I do take out the ice cube tray just in case.
We also turn the gas off at the taps which are under the worktop in our vehicle. We have an underslung tank which has a valve on it you can use to isolate it - but we've never bothered with that though we would for the Chunnel.
Other does and don'ts? Make a note of the deck number the vehicle is on and staircase you used to get up to the main decks. This avoids the frantic "where is it?" search I've seen many times! Brittany Ferries have folk handing out cards with this info but I'm not sure everyone does.
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
how much do you realy need in the fridge? I assume your travelling to europe everything is available once you dock
we travel with very little in the fridge
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
Thought of another one. Turn the water pump off. Not essential but if something sprung a leak it avoids coming back to a flooded vehicle.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Fridge will be ok. We leave ours on the Spanish 24 hours ferry and never had any problems
But buy a travel kettle and two pin adaptor so u can make a brew in the cabin (on the longer crossings of course).
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
In addition to DBK's good advice about putting a frozen bottle of milk in the main compartment, it also helps if you fill the freezer compartment completely with frozen food. Do not put in the fancy packaging the stuff comes in. Take it out of that,(keep the instructions if you must) but essentially turn the freezer compartment into one solid block of iced food.
DanielFord
3,020
3,086
You are required to turn off the gas supply before boarding. On our last crossing, to Hook Of Holland, the security were pulling all motorhomes out of line and asking them to turn off gas whilst they watched you do it.
Simple answer, don't have anything in the freezer that will spoil, and put ice packs in the fridge. that will keep it cool for the whole crossing :D
7,512
19,938
Lanzarote
Nil by mouth
Lots
I've never been asked or seen anything like that.
DanielFord
3,020
3,086
It's a first for me also I have to say, although, amusingly the guy stood by the toilet cassette door when I exited, and I had to say to him "actually the gas is the one with the LPG sign on it!" :D
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
As a former ferry company employee I can assure you I insisted on it whenever I saw a motorhome or caravan in the marshalling area. Please read the conditions of carriage and it should be very clear. Propane and butane are heavier than air, this doesn't matter too much outside but the car deck of a cross channel ferry is an enclosed space. Where would any gas leak to and disperse? If you have the fridge on gas where are the products of combustion meant to go?
Please turn off the gas.
7,512
19,938
Lanzarote
Nil by mouth
Lots
in 30 years of ferry travel I've never been on a closed deck.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
I asked for hook up and got it. :)
4,093
5,910
SW Scotland
LP Coachbuilt
I'm interested in not traveling on a 'closed deck', all cross-channel ferries are, all sea-cat style and only CalMac have open decks where I live. It's irrelevant anyway, the regulations prevent even Oxy-acetylene gases being carried in the engine-room, it is considered too dangerous.
11,189
17,841
HYMER B644
Hi,
The answer is no. Just pack lots of ice in the fridge or rather ice packs.
The food will stay cool or go to a restaurant or supermarket when you get there.
Would you want to be responsible for a ferry fire in the middle of any stretch of water?.
TM
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
Newbie question alert, if the gas is turned off and your not on ehu, wouldn't the fridge switch to 12v?
TheBig1
17,630
43,324
Only if the engine is running.
nekarsulm
25
11
Cavan, Ireland
Autoroller -5.Fiat Ducato
ten years
I've only ever been on Irish Ferries "Oscar Wilde" to Roscoff and Cherborg, and at the ferry port check-in they hand you a card notifying you to turn off gas at the cylinder. El. hook up is available if requested.
1,228
820
Wiltshire
Low Profile Hymer CL 554
Since May 2014
Our Hymer uses the engine battery when driving but it does not switch off when the ignition is turned off. Our fridge has the switched off or it will flatten the batttery on the ferry. :eek:
EyUp
260
396
Yorkshireman living in Surrey
Majestic 180
newbie
I mentioned switching to leccy for the crossing on post 5 but it didnt get answered. Seems like a sensible solution to me.
Surely a healthy leisure battery or two can cope with a channel crossing? Your not crossing the pacific ocean !
