fiat x250 air bag (1 Viewer)
JohnM
650
179
Central Scotland
CClass
Since Feb 2009 and 40yrs c/vaning
Just back from a few days away. Airbag light/failure notice on. Have checked manual, but to no avail. Any ideas? No sudden braking to cause this coming on, only had drivers seat out to sort out 'knocking noise' (which is now fixed).
17,641
43,445
you DID disconnect the battery before unplugging the seat wiring didnt you?????
MikeD
3,936
3,697
London
IH PVC
warning light
Sometimes once you have disturbed the wiring to a sensor it automatically resets but often it needs a computer to be plugged in.
BMW are like the latter, the light will not reset without a computer reset.
Ford monitors the situation each time you start the engine and if after predetermined number of "fault clear" starts it resets itself.
Not sure about Fiat. But nothing to lose to try the "ford" fix.
I hope this helps :thumb::thumb:
17,641
43,445
yes the sensor detects a wiring fault.... try disconnecting the battery for 1/2 an hour to clear the memory or otherwise it may need to be reset using a code reader
first though disconnect the battery and double check you plugged the wires back in properly under the seat you removed
18,041
48,179
Just in case it isn't clear the reason for disconnecting the battery is to ensure the airbag doesn't go off - which is not just expensive but could do you a lot of harm if you are near it when it goes off. Think broken neck.
JohnM
JohnM
650
179
Central Scotland
CClass
Thank you for the replys will check it out probably tues,and will let you know the outcome.
Thanks'JohnM.:thumb:
JohnM
JohnM
650
179
Central Scotland
CClass
Does this help?
:thumb:
Thank's Sandj for the link it's me driver's side and it's not coverd in the computer.:thumb:
JohnM
JohnM
650
179
Central Scotland
CClass
x250 airbag update
update on drivers airbag fault, went out today and refitted cable under seat started engine a few times and all seems well, no light or computer warning:Smile:.So thank's to all funsters who offerd help and advice. JohnM.::bigsmile:
