Fiat Sea Dinghy 4 berth Payload?
Discussion in 'Motorhome Chat' started by georgendah, Mar 8, 2013.
  1. georgendah
    georgendah Read Only Funster
    Jul 6, 2012
    38
    10
    Shrewsbury
    Hiya All,
    Does anyone out there is the ether what the payload of Fiat Sea Dinghy 4berth.
    Thanking y'all in advance.
    Neville:thumb:
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,223
    7,315
    Nr Watton in Norfolk
    There will be a plate under the bonnet with the maximum total weight and each axle weight.
    You then need to load your m/h with everything you normally travel with including any water, fuel, passengers and pets and weigh it on a weighbridge (do the whole van and then one axle). Check the results against the plated weights to ensure you are not overloaded.
  3. georgendah
    Jul 6, 2012
    38
    10
    Shrewsbury
    I kinda know all that gear . Was just wondering whether some one out there would give me a rough idea to assess how comfortable I am against the payload spec
    Regards
    Neville:BigGrin:
  4. busby
    busby Funster
    Aug 18, 2011
    3,385
    3,198
    derbys
    You will need to weigh the van empty and then subtract this from gross weight on the vehicle plate.
  5. icantremember
    Sep 2, 2010
    5,223
    7,315
    Everyone has different requirements for what they carry so the only way is the weighbridge method. You should get a print-out from the w/bridge which would be useful to show the authorities if you get stopped.
  6. georgendah
    Jul 6, 2012
    38
    10
    Shrewsbury
    You do sound very expert on this area - I am convinced!
    Regards
    Neville
  7. icantremember
    Sep 2, 2010
    5,223
    7,315
    Hi Neville ... not a case of being an expert, I'm still learning and as far as I am aware there is no other way that can be so accurate.
    Brian
