fiat red key (1 Viewer)
con-tiki
457
187
Leeds, West Yorkshire
A class Hymer
since 2009
I have the fiat ducatto chassis on my 2000 reg B564. I've only got 1 ignition black key. The master key has been lost along the way. I can get another keyed 'cloned' to have a spare, but worry in case I need this master key in the future. I want to change the stereo cassette player for a cd player. As I have to disconnect the battery, will this cause any problem?Fiat have said if I don't have the master key, then the ECU, ignition and a new set keys will have to be replaced at a cost of £1000 ! :Eeek: What a stupid system, as Fiat should have known that some people don't look after their keys.....I didn't realise this when I bought the motorhome :cry:
Shirl
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
hi in the documentation we got with ours all be it a new van there was a small card that has the electronic key code and a physical key code numbers on it.
they may have misplaced the keys but this may be in the documents you got from the previous owner.
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
I have a Peugeot Boxer which is basically the Fiat Ducatto by another name and I had my valves replaced in the engine which involved disconnecting the electrics. I left the keys with the garage but kept the red key at home. When they came to test the engine when it had been reassembled they could not start it without the red key, nor could they have managed it without a code that the previous owner had kindly written on a tag with the red key. I think they could have got the code from Peugeot but it would have increased my bill for the time they spent looking.
So yes the red key is essential - whether it can be replaced other funsters may be able to advise, look out for a reply from Peter at John Cross motors I am sure he will have the most accurate answer to your problem.
Sorry not a great deal of help other than confirming you are in dangerous territory without your red key. Don't touch the radio.
Norman
beachcaster
3,044
3,161
east sussex
a few years
When I bought my secondhand autotrail /fiat..I got 2 sets of keys.
But I cant find the card with electronic code anywhere.
Does this mean that if I dissconnect the battery I will be in trouble ?
I take it this only applies to the vehicle battery and not the habitation battery ??
barry
43,329
49,446
i believe the only way to get a new red key is with a new ECU and immobiliser......around £800 to £1000.
the red key not only holds the programming codes for replacement keys but also the access/reset code for the ECU and immobiliser programming.
i believe the PIN cards were only issued AFTER the red key system was discontinued...around 2002/3 i think.
Active (programmed) black keys are now relatively easy to get, but not the red key.
43,329
49,446
barry
Fiat should be able to supply the code via the VIN number...but there will surely be a charge :Sad:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I occasionally deal with Fiat cars not commercials and I think Pappajohn has got it in one, though I'm not sure about the date it changed to the black twin key set-up.
The only car I ever took in without the red key cost the dealership almost £1000 to remedy.
43,329
49,446
just found a cheaper workaround if the ECU needs replacing...
i don't know anything about these, but my feeling is the immobiliser circuit may be disabled so your insurers may not like it !.
'Free running' ECU replacement units without the need for a red key.
<<<HERE>>>
Just as i thought.....disabled immobiliser circuit in these.
from the same website.
Free running ECU’s
Free running ECU’s are specially built with no immobilizer code function programmed in to the EPROM. These units are very useful when a problem arises with the vehicles coded key immobilizer function, it can be very expensive to replace the whole coded key system usually around £1200.00, we can supply a free running ECU for around £195 depending on application.
A free running ECU is also useful if you are not sure your problem is coming from the ECU or the coded key immobilizer, free running ECU’s cure both problems as they run independently of the vehicles immobilizer. These units will not need to be reprogrammed by the main dealer saving further fitting costs.
All free running ECU’s have a 2 year unlimited mileage warranty.
con-tiki
con-tiki
457
187
A class Hymer
since 2009
Apparently the system as well as having the master key (red key) they also had a card with the electronic code and mechanical codes on it, but the ones for the uk market were not issued to owners because the uk insurance companies would not allow the owners to keep them. I have been told that you can get the card from Fiat for a charge of about £30, but itdoes not address the problem of the 'lost' master key.
Shirl
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Shirl,
It does depend on the age of the van, the older vans did have a red key issued at sale.
The later ones had the key code card, sorry cannot remember the exact details but the workshop staff will know.
Peter
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
i disconnected the battery on my ducato to replace the radio and did not have a problem , if you are worried leave the battery connected and remove the fuse for the radio
Jul 28, 2010
1,710
617
The world
Small car
Shirl
it is one of the big cons the dealerships have ford charge £20 for the key blank then more to cut it then over £80 to set the chip one big rip off
BMW Mercedes Ford, fiat and all the others do the same
it can be cheaper to replace all the locks
with new barrels and Keys
or you may get a full set from a breakers yard
a lot of extra work for no real gain
normanandsue
1,871
21,571
van conversion
This is a bad expereince and the only thing to do, with a bad experience is to learn from it and pass the experience on to others so they are made aware of the dangers when buying a second hand van.
Does anyone know when the red key system came into use and when it was no longer in use?
This information would be helpful to people buying motorhomes of around the 1998 vintage so they know when to ask for a second set of keys including a red one. I for one was not aware of the significance of the red key until my engine was rebuilt last year and it is only by the grace of God I was not faced with the same problem as you.
Norman
lesleyjean
1,748
2,392
Hi,
mine is a 2002 Swift Kontiki and I have the red key system.
So still red keys in 2002
Lesley
beachcaster
3,044
3,161
east sussex
a few years
Shirl
Just went into my fiat dealer and he confirmed the above.
No card needed for a recent Fiat
barry
43,329
49,446
barry
been searching the web about this and i found.......
if your ignition key has a 2 stamped on the metal part of the key and possible a diamond, then it is second generation and no red key is needed.
still cant find those elusive dates though. :Doh:
Gorsecover59
45
17
Jersey
Swift,Lifestyle 530l
new
Recently got a spare key for my new ( to me) 2002 Ducato sundance.
Key £155
Code £35
Coding charge £38
Total £228 At least Dick Turpin wore a mask..........but then again this is Jersey and we are all millionaires !!!!!
Would be interested to know when the red key "thinghy" was changed to just a code........and am I in that situation as I dont have a red key.......or was it just not passed on ????
Many Thanks
Martin
Gorsecover59
45
17
Jersey
new
Able to answer my own question..........
My handbook says (if all else fails read the instructions) my model which is a 2002 sundance only had 2 keys and no red one.
The keys also have the number 2 stamped on them as previously posted.
Martin
Gorsecover59
45
17
Jersey
new
Moi Again
Forgot to mention I have my engine battery isolated whenever we are not using the van and as of yet have not had a problem..........so no worries with a flat/disconnected battery.
Martin
43,329
49,446
Key £155
Code £35
Coding charge £38
Many Thanks
Martin
Almost certain it was 2003.
early JTD's may have one (not sure) but later (2003 on) JTD's dont.
a 2003 ducato may be an older year model just registered later.
con-tiki
con-tiki
457
187
A class Hymer
since 2009
The Hymer originated from Madisons (motorcaravan centre) Preston. I phoned their number and was transferred to Brownhills. The gentleman told me that there is no master key with Fiats, just Fords ! (wrong ! ) Told me that I should not have a problem with the Fiat.....I told him that my handbook says that there should be a master key.....so needless to say no help there. I then phoned Fiat in Edinburgh and spoke to a very helpful parts manager who is going to look into the matter. He seems to think that disconnecting the battery should not be a problem... ( I will await further info from him before I change the stereo ).
I came across this website which looks promising, unfortunately they are in the London area, but there must be others who can do the same job more locally. Broken Link Removed
to be continued.........:Eeek:
Shirl
