Fiat fuel filter leaking...AGAIN Oh Please! (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
So many questions that you insist upon but you are in the trade and should be telling me what a mechanic does to change this filter element.
I am satified that I have done mine to the best information available unless you can tell me any better.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I was hoping to get sensible simple Yes or No answers
debating Blue print or others was not on my agenda
From such an apparent source of researched knowledge the questions should not be hard
PS Dave Newell you seem to be applying to much tourque ? is your tool saying differant to others in use?
Responding to any further flippant comments is also not on my agenda.
Im trying to have an intelligent Q&A session
My mistake Geo, I'm sat in a cold field in Newark and quoted 35nm from an old and tired memory. The correct torque (30nm) is, as Techno has proved, moulded into the filter housing itself. I bought my tool form my parts supplier and it is the Blue print one.
D.
Techno
Jul 28, 2010
15,475
20,756
May 2010
BTW my original equipment filter and housing that I removed were both made by UFI and so is the ebay replacement
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Did you have help with that comment or is it all your own work:RollEyes:
All my own, All my own.:ROFLMAO:
By the way, I have been in the Motor trade since leaving school 45 years ago, and am deeply saddened to see the way it is now.
Glad to be getting out.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
http://library.docent.isvor.it/uplo...cia Didattica Fiat Ducato seconda fase_GB.pdf
I'm not slating the motor trade. I'm sure there are very many vans out there that had their filter changed correctly. Why defend incompetence
Why defend incompetance
A very good question I wasnt expecting, I have to date seen no evidence of any
What would be a reasonable time to stand and watch a fuel housing for leaks after fitting
would it be 10 mins 1/2 hr 3 hrs what?
what happens with the 99.9 % of leaks that happen days weeks after installation
Who is to blame for those.
I can Guarantee Dave did not send either of his two failures out with a leak. so where was the incompetence just who did the blame lay with
Answer just that one question satisfactorily And I will drop it
I can tell from the change in tone of your reply's you are now getting warm under the collar and would rather end this conversation
This forum is constantly knocking someone these days im looking to play devil advocate
You as an amateur fit 1 maybe 2 with a 100% success rate taking possibly half a day to do it and hail yourself competent:Cool:
I fit 102 with a 99.9 success rate in 15 mins each and im the failure:Doh:
WE DO NOT SEND VEHICLES OUT WITH KNOWN FUEL LEAKS
If we did that would make us Incompetent
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Why, were you deemed incompetent too? or were you like me just purfik
ps terrible stutter you have there
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'm not the least bit hot under the collar :roflmto: To the contrary I have given useful information for people to make their own choices (with pictures) all you do is defend.
Half a day? does it take you so long? an hour including pictures, probably 30 mins next time
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Come on guys, let's get back to the original problem here, please!!
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Sorry to see you taking this so personally, as far as I can see you have not been involved in,or blamed, for the leaking filter mentioned in this post.
I know I have not said anything against you & I'd like to think no one posting on this thread means anything against you either.
I'm sure ( or at least I hope) there are still a few reliable & reputable people involved in the motor trade, it's just I have not had first hand experience of any lately.
PS No just getting too old
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
stop digging Geo I think you know you should be using the correct tool its the same one that has been working on other cars for 10 years or more it clearly tells you on the filter how to fit it.
As for any Fiat dealer denying the use or existence of such a tool they clearly are incompetent
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
[HI]just change it[/HI]
Looked at this item before, it comes u as not compatible with my M/H, mine is registered as a Ducato33 130 M/Jet van, cannot see 33M/Jet on their listing.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Contact the seller the inbuilt compatability guide is very often wrong. Also I'm sure they will acquire one if it's not.
Techno
Jul 28, 2010
15,475
20,756
May 2010
One extra snippet of info I will add.
This blueprint tool is designed to sacrifice itself to protect the filter housing. Overtightening beyond 30nm will result in the cup part that sits in the vice beginning to twist and deform thus absorbing any attempt to overtighten.
Also I was incorrect when I said you only need a pozidrive screwdriver :roflmto: You will of course need a 13mm spanner or socket to remove the headlight. EDIT 10mm :Doh:
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
doing mine (with tool from ebay) and detailed information from sir mr techno (thankyou) next Saturday, after this thread have enlisted the help of a friend (he builds cars /rebuilds engines, races and tunes motorcycle engines) wish me luck :thumb::thumb: silly really as I have always serviced my own vehicles but when it comes to specialist work or something to technical always take it to an expert ..............but a fuel filter:ROFLMAO: fiat must be having a laugh, as with most things with vehicles these days made too difficult/special tools/computers/etc.for the diy'er
DuxDeluxe
14,659
72,803
Planet Zog
A woosh bang van
In the early days of cam belt replacement
In cases of premature cam belt failures and warranty claims running into ÂŁ1000s of pounds for the resulting engine damage
The first question from the belt supplier is what tools were used? Ie cam belt (tensioning tool)
Don't even contemplate saying you use a Snap on one if something else was specified
if you cant prove 100% you did everything right you must have done it wrong so no compensation
its only getting worse these days with everything getting more complex and a proliferation of Forum Barrack room lawyers
Hence my seemingly reasonable questions
Geo
Good points and thanks for posting - just shows the days we live in. I think that Techno's answers cover the liability issue. I must admit that I did not check my copy of the Fiat manual that I have on disk.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Indeed I do im trying to find one, but for reasons I cant fathom i can not get a definitive answer only worthles opinions and spurious manufacturers versions
And Im deadly serious :Eeek:
Look how silly it looks, and I might be defending myself on a manslaughter charge
Question from the Judge in the small claims court after establishing a tool was use to tighen the filter that leaked fuel on the road and killed a cylist
Is the tool Fiat approved Yes or No
Answer from Me
Well yer lordship Techno has establish on Motorhome Fun:Doh: You know techno he's an amature DIYer does everything cock on ya know he proved it
Yes Geo but Our "Expert" witness from Fiat say's Its a Blue print tool:Doh:
Etc
Im not knocking anyone, I asked a few simple questions and get sarcastic answers
such as "am i saying all the tools I use are approved. That helped How?
Followed By constant reference to "Incompetent mechanics" Bollox its the equipment thats crap not the skills of the man working with crap
I take it that Techno has had one leak thats why he sourced the "Proper Kit " so by his own definition he is incompetent Yes or No or i the question too difficult
Go on someone I dare yall answer yes or no and say why
Dont bother already know the answer:RollEyes:
Techno
Jul 28, 2010
15,475
20,756
May 2010
No I've not had a leak ever
Just what is the Fiat approved tool then GEO? if you don't know and Fiat don't what chance as anyone else :ROFLMAO:
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Followed By constant reference to "Incompetent mechanics" Bollox[HI] its the equipment thats crap not the skills of the man working with crap[/HI]
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: Yeah right.
Techno
Jul 28, 2010
15,475
20,756
May 2010
What I don't understand is why this is being made a Fiat issue at all. The filter housings are manufactured by UFI not Fiat so it should be a UFI approved method of replacing an element.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Indeed I do im trying to find one, but for reasons I cant fathom[HI] i can not get a definitive answer only worthles opinions and spurious manufacturers versions[/HI]
[HI]Is the tool Fiat approved Yes or No[/HI]
Answer from Me
Etc
[HI]Go on someone I dare yall answer yes or no and say why
[/HI]
Please read the answer
Geo the following you seem to have dismissed as not published by Fiat and you were given a link in a previous post
is a page from the FIAT SPA training manual it clearly describes the tool and part number.
I would like to ask your method of changing this type of filter as it has been used for over 10 years and you said you have changed many ?
You also said you pay a large amount of money for technical data access so what does that tell you to use?
beachcaster
3,044
3,161
east sussex
a few years
This thread has turned to jelly....and turned personal. Relax chaps.
Its a crap design........its too expensive........and Fiat chose to use it .
It comes with instructions on how to put it on .
There must have been better ways of skinning this particular cat.
Some designers should be shot .
barry
Techno
Jul 28, 2010
15,475
20,756
May 2010
I agree that to make this housing out of plastic is ludicrous, but Istill think that the seal is the culprit, it is too thin and is not compressed enough to give a reliable seal.
Has anybody bought one from Opie oils, the link was in a previous post, cannot be any worse than the Fiat item, this ongoing problem is destroying my enjoyment of owning this M/H. :cry:
I checked a post on another forum and it seems that the one sold by Opie oils is the same unit but cheaper at ÂŁ92 delivered
Ignore the generic image
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Ordered new filter assembly yesterday from e-bay, arrived at lunchtime today, fitted it this afternoon, no leaks, fingers crossed, hopefully end of saga.
Fiat dealer had told me that this plastic type of filter often leak, and that they are not interchangeable with the metal type 2014 filter, as far as they know.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Good luck Peter, hope it holds this time matey.. ( Your question certainly stirred things up didn't it) :Smile: Mitch.. Regards to Beryl and keep smiling...
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
I hope that this is the end of it, I guess you are getting exited about upcoming trip, we hope it all goes well, Best Wishes, Pete & Beryl.:thumb:
