Fiat Ducato Radio Noise When Switched Off (1 Viewer)
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
Since 2015
Ola folks,
Ref:- 2015 Fiat Ducato
My radio sounds like it has a fan running in the background when switched off. Anyone else have/had this issue or heard of it?
Cheers,
Steve
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Can't really help except... I'm sure there was a thread I read on here a little while back asking the same... That recieved replies :)
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Since 2015
Thank you. Hope it wasn't me who started it :doh:
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
We have an integrated media/nav/radio unit which has a fan running while it is on. It takes a while to shut off though. Are you sure are are actually turning it off and not just muting it. If it's like ours (also 2015) a short press mutes the sound, a longer press turns it off. The fan takes several tens of seconds to shut off (or it certainly seems like it).
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Since 2015
Doesn't look like it is just muting, ie, when I switch it back on the Fiat logo appears. Anyway, I will give this a try because I am hoping you are correct and I am a dummy ;). Thanks from another Steve c(y)
Minxy
32,651
66,544
E Yorks
Carthago Compactline
I've just had a read up about this on various forums etc for you and it appears that whilst you can alter it on the X250 to extend it to 180 mins, you only have a choice of either 0 or 20 mins on the X290! o_O
I've got a non-standard radio in my X250 so am limited to 60 mins max which is a pain in the bum. :mad:
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Since 2015
Tried this but to no avail. Will have Fiat Professional take a look at it when they "fix" the dash lighting.
Apr 29, 2014
462
253
Warwickshire, UK
Chieftain
Since 2004
As regards the radio can only say battery use to drain even with solar and battery mate so tried taking fuse out for radio hey presto radio still on even though turned off now all I do press eject fascia button saves taking fuse out hope this helps someone
Oct 26, 2016
162
54
kent
Burstner Elegance 810G
since 2003
We have a Burstner Elegance 810G 2015 and ours doe's the same when switched off after about 10 seconds or so fan stops, but make sure you switch the radio off properly hold the on/off button down for about 3-4 seconds and you will hear a little bleep and then you know your radio is off.
good luck Joe
Lenny HB
53,430
149,988
On the coast in West Sussex
Hymer B678 DL
Wired mine to Elektroblock so it runs off the leisure battery.
