fiat ducato parts needed (1 Viewer)
georgie boy
143
15
liverpool
Concorde charisma
Hi all
Having a few problems with my auto-trail Cheyenne, its a 2007 fiat ducato, been getting engine management Light coming on, So took it to my local garage and they put it on the machine which reads the problems, but not so good at mechanics so any help or advise would be appreciated .
first error was PO683 which read preheating control unit.
second error was PO402 which read EGR valve,
third error was PO 638 which read throttle control valve.
Can anyone tell me if it would be best to replace all these items on the van, or best to replace one by one to see if it clears the faults,
any help would be really appreciated .
Regards George
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Forget the error codes for a minute
What was the actual problem you had ?
We had similar type codes and it turn out thermostat sender unit wire had broke telling the 'Brain'the engine was still cold when temp was up
Edit problem is there are plenty of plug in technical twerps but fewer and fewer mechanics
georgie boy
georgie boy
143
15
liverpool
Concorde charisma
Thanks for your reply. problem is when I start the engine it wont rev up just runs at idle, but if i turn the engine of the back on it runs as normal. so basically have to turn the ignition on and of a few times before firing it up ?
regards George
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
George, if all three of those sensors are gone you would proly be doing about 6 mpg, and VERY slowly !!!
Get them to clear the faults and what ever comes up FIRST after they are cleared you fix..
But also make sure the earth point that the ECU feeds from is ok !
georgie boy
georgie boy
143
15
liverpool
Concorde charisma
Thanks for your reply, regarding the ECU can you tell me wot it is and were i find it ?
regards
georgie boy
georgie boy
143
15
liverpool
Concorde charisma
Cheers think it would be best to put in a new EGR then test.
regards George
DanielFord
3,020
3,086
regards George
I once helped out a friend who had the EGR error on a VW Polo, they are fairly simple to remove and clean, the whole job takes about 2 hours. A bit cheaper than replacing.
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Whenever iv seen one of these detector things working you can almost guarantee it will come up with egr:xeek:
