Fiat Ducato 2.8 JTD gear ratios
Discussion in 'Tech/Mech General' started by reynardracer, Oct 11, 2016.
  1. reynardracer
    reynardracer Funster
    Aug 10, 2015
    61
    7
    Twyford
    Can someone with a motorhome with one of these 2.8 JTD engines from around 2004 provide me the gear ratios for the 5 speed manual. My old 2.8 TD has a .8 4th and a .6 5th gear which are not good for my towing application.
    Peter
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,408
    5,246
    St. Helens MERSEYSIDE
    Hi, I have the same engine and used to tow a car occasionally and would have liked a little more oomph ,so at one of the shows I asked WOW tuning to remap my van and it was like driving a different van the power and torque were there and mileage was not noticeably different and if you didn't like it they would put back your original settings so that may be something to think about rather than mess about with gearbox ratios .(y)
  3. reynardracer
    Aug 10, 2015
    61
    7
    Twyford
    Thanks for that. I don't have one at the moment but an earlier model with the 'bad' gear ratios. just wanted to know if the later models had a different gear set.
  4. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    I fitted an Ebay tuning chip to mine. The difference in power selected for more torque was significant and startling.
  5. reynardracer
    Aug 10, 2015
    61
    7
    Twyford
    Cannot chip mine as it is an earlier mechanical injection version.
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,372
    9,815
    there are 2 different gear ratios for 5th but 1-4 are the same afaik
  7. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    If its a 2004 jtd as you said in your op then it is not mechanical injection. There was a lower 5th gear option on x244 models (reverse is left of 1st, the earlier x230 had reverse to the right of 4th). The higher 5th gear is 0.733:1 and the lower gear is 0.58:1. The two gears for the lower ratio are £179.21 and £77.95 +vat from a Fiat dealer.
    D.
    • Like Like x 2
  8. reynardracer
    Aug 10, 2015
    61
    7
    Twyford
    Hi Dave,
    Many thanks for the info, just what i was looking for.
  9. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,964
    2,794
    Kendal, Cumbria
    @dave newell lvs
    Dave - do you know if the higher ratio 5th is still available? I have a 2005 Hymer B584 that runs 3200rpm at a genuine 65mph and which feels very low geared - even when towing a car trailer.
  10. dave newell lvs
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    My local Fiat dealer's parts dept gave me the ratios and prices about four months ago so they should still be available. In view of your speedo error I'd guess you have 15" wheels, changing to 16" would solve both problems I think.
    D.
