Fiat Ducato 2.3 v's 3.0 litre (1 Viewer)
Oct 26, 2014
736
1,433
Lincolnshire
Adria Coral Supreme 680st
since 2001
Hi,
we are going to look at a MH that has the 3.0 litre engine, the van is 2010 registered,
I've read in the past about Ducato's having a judder when reversing up steep gradiants, does this apply to both engine sizes?, and also is there anything to be wary/ aware of on the 3.0 litre?
Andy
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
Our MH is a 2010 'van based have a 3.0 Fiat base. Have done just over 6000 miles in it in the past 12 months - it's not missed a beat.
Have reversed it up inclines - no sign of any judder.
Have taken it up sever very steep hills, including 20% in Peek District and in Scotland - no issues at all, just takes it in it's stride.
Initially I was going to get it remapped, but after driving it for a year, have decided it doesn't need it.
Not sure if it suffers the same leaky fuel filter as the 2.3l - someone might be able to advise.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I have no judder (2008 3.0 comfortmatic) If the van is plated at 3500 2.3 is hugely adequate. Mine is 4250kg and as luck would have it the first owner opted for auto at great expense. I can't imagine driving anything else as it is such a pleasure.
D
Deleted member 29692
Ours is 2.3 and 3850kG and is fine. All the power I need and no sign of any judder so far.
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
I believe the 3.0l is a chain cam engine, not to be sniffed at.
Apr 21, 2008
822
2,066
bedford
Mine is a 3.0 auto, 14000 miles and judder,clutch slipping and burning in auto, but was okay in manual. Not sure if I was going to get home from france, but then worked okay most of the time. Going into fiat garage 27 th to find out what is wrong.Engine great though
lou020
489
360
huddersfield
autotrail chieftain
since 2010
Awesome engine the 3.0 with huge amount of torque. A real joy to drive,,Makes my old 2.5 TDI seem prehistoric.
TheBig1
17,630
43,324
ive changed my filter regularly and not had problems i take it out and remove top by wedging the body loosely in a vice a smear of silicon grease on the threads helps
there is a special tool and cradle available to make filter changes easy. bought mine for under £20
TheBig1
17,630
43,324
forgot to say, the 3.0l is great and very capable, but the clutch is stupid expensive to replace and can be a very weak link. had one literally shatter into pieces and the garage had seen several do the same
mikebeaches
5,394
8,601
Bristol
Rapido V68 Van Conversion
Since 2009
We have a 2010 Ducato (purchased October, but believe chassis built February that year) 2.3l manual gearbox and plated at 3,500kg - no problems with clutch reversing up very steep slopes. Have covered 25k miles now, and all good so far.
Would like a comfortmatic gearbox though.
Mike
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Ours is a 3.0L manual.. Great engine pulls like a train and tows effortlessly..
Drives very smoothly and no judder.. or leaks.. :rolleyes:
Mar 17, 2013
389
389
Devon
Carado T339
Ours also a 3.0 l manual 2007 - great engine and no probs at all since we have had it - apart from after a service when the mechanic put the oil filter back on cross threaded! Lovely to drive - we are so pleased with it!
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
we have gone for the 3.0ltr option in the Arto we have ordered,so are hoping for good things from it(y);)
Brian & Jo
Southampton
522
318
Hampshire
Since 2009
Done 12000 miles since new in 2013 in our 3L Auto. No problems at all, our last trip to Croatia and back returned 26.9 MPG. Admittedly that was on the onboard trip meter. Wouldn't go back to manual.
Minxy
32,659
66,565
E Yorks
Carthago Compactline
The ONLY way to find out if there is a problem is to give it a very good test drive, make sure you reverse up an incline for some distance if possible, also you should be able to check with Fiat if it has had any 'fixes' done. If there is any sign of judder walk away ... it isn't worth the hassle!!!
Mar 17, 2013
389
389
Devon
Carado T339
Mechanic used loosely :LOL: takes some doing getting that wrong.
Yes! as you imagine we were not happy! especially as just got off the ferry to one of the Scottish isles - luckily Safeguard got us going again within 50 mins! incredible.
Drexxer
Oct 26, 2014
736
1,433
Lincolnshire
since 2001
wow !
thank you for your reply's, seems we should be onto a winner with the 3.0l engine then,
I like the extra torque as we have just sold our 5cyl 2.5TDI transporter and that was also a great torquey engine
Andy
