Fiat 2.5 Td Sump Plug Washers, Bet Someone Knows (1 Viewer)
bhs
214
137
Louth
b class
since 2006
  • As I change engine oil every 20 minutes thought I'd buy some sump plug washers, the garage has done it up to now and I can't find detail, Mr Google Coming up with 2 sizes, without taking it out I reckon it's this one, thanks
  • Inner Diameter: 22mm
  • Outer Diameter: 30mm
    Thickness: 1.5mm
    Fiat Ducato 1999 2.5 TD fitted to Hymer B574
Jaws
23,836
72,484
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Go to halfrauds and buy one of each size.. go on, spend that 80p !!
bhs
bhs
214
137
Louth
b class
since 2006
Change oil much more often than I need I'm sure, as for Halfrauds (well named) they are £1.99 I was thinking of buying several for my little box of treasures! plus the nearest store to me is 15 miles, every day in every way I'm trying to be less tight, As kermit said, it's not easy being mean.
Jan 26, 2010
577
1,493
Conwy, North Wales
Relay self build
This is from the Europarts website with info for my Ducato (2.3td)
Jaws
23,836
72,484
Thetford Norfolk
C class, Chieftain
Changing oil too often can be as bad or worse than infrequent changes
All modern oils have a detergent component in them.
That component takes ABOUT 2000 miles to dissipate..
So changing oils too often means you are running the engine on a detergent oil which is not a really good thing..
As an aside, if you do get the right size I can get the washers for pennies BHS.. happy to get them and post em to you at cost
bhs
bhs
214
137
Louth
b class
since 2006
Thanks Martin, that will do nicely
bhs
bhs
214
137
Louth
b class
since 2006
Thanks Jaws will get back to you when I confirm size, I have been in the habit of changing the oil before each long trip, perhaps I should just do the one change a year? We rarely exceed 6000 annually.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Use these. They seal better initially than copper or aluminium and can be re-used.
Broken Link Removed
Smaller quantities may be available (I didn't look very hard) and they're also available from agricultural machinery repair places. In case there's one local to you :).
Jaws
23,836
72,484
Thetford Norfolk
C class, Chieftain
Even that is a bit ott..
I know people who SELL oil will tell you differently but after 15 years on the spanners I have yet to see a tin of oil with a sell by date on it..
The folk who built the engine know best.. What do they recommend ?
Aug 18, 2014
23,782
133,685
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
My mate bought a new 1,9 LDV van & religiously changed the oil every month !
Used to come out like Golden Syrup , same as it went in.lol:D
I doubt that he did 300 miles a week. Still going well when he retired some 7 years later.
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
I just go to the boat yard and get my copper washers 60p each (y) can you send me your used oil it still got 10k left on it :rofl:
