Fiat 130 2013 'Injection system warning light' ...... no throttle response!
Discussion in 'Tech/Mech General' started by Chockswahay, Apr 12, 2015.
  1. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,796
    Hi everyone. I drove the van this morning about 10 miles then stopped on top of a very windy hill in South Wales. About an hour later started the engine and the 'injection system failure' warning light came on. The throttle did not respond (press... no revs!). I switched off, restart then after a while it worked. However the light stays on and power feels 'reduced'......
    We did have this a year ago, called Fiat Assist and they sent out the AA/RAC (can't remember which). The man said that this can happen in really windy weather! (hence reference above) and he said it was the Exhaust Gas Sensor was faulty........... anyway he 'reset' it with his box of tricks and it has been fine ever since (that was at 6000 miles... now at 26000 miles).
    The van had a full service at Fiat a week ago. It has been running like a dream. Another possibly spurious thing..... my son and I took the radio out to look at the back....... wondered it this may have caused an earthing issue?
    Anyway, we drove back to Cardiff (40 miles) but the light is still on. Before I either:
    A/ call the AA
    B/ take it to Fiat in Risca
    Does anyone have any thoughts or advice please?
    We are off to Italy on Tuesday and this is bad timing :mad::eek::eek:
  2. f6c
    f6c Funster
    Nov 7, 2010
    3,259
    871
    gloucestershire
    Sorry can not Help Chockswahay hope its not serous.
  3. Zajacp
    Zajacp Read Only Funster
    Sep 11, 2012
    92
    57
    Cheltenham
    Sounds like throttle body unit ,some times they get rain water in them when left standing for a while,get in through the front scuttle and runs down. I had the same problem just cleaned it up a sprayed it with wd 40 it's been fine since .as for the lights they can be cancelled by turning the ignition on and off 5/6times saves paying a garage to turn it off.
  4. Chockswahay
    May 29, 2012
    3,097
    4,796
    Thank you. As it happens I called the AA..... they found a fault code in the exhaust gas sensor........ reset it and away we went!
    I also took van to Fiat Pro in Bristol and they ran full diagnostic check........ hopefully all ok now!
    Cheers..... off to Italy now (y)
    • Like Like x 1
  5. Zajacp
    Sep 11, 2012
    92
    57
    Cheltenham
    Have a good trip,hope all goes well
