Fiamma crank handle
Discussion in 'Motorhome Chat' started by Greenacres, Mar 17, 2014.
  1. Greenacres
    Greenacres Funster
    Jan 10, 2013
    59
    9
    Stoke on Trent
    I have inherited a very long,telescopic crank handle,to go with a F65 awning. The trouble in that it is not telescopic enough. The only place that I can store it out of the way is to put it vertically, on a wooden panel at the rear. What is used to clip the pole on?I have seen pics of small brackets. What are they made of, how do they fasten on, and where can I get a couple? I have checked that the rear door will close with it positioned here. Thankyou
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,533
    7,666
    Nr Watton in Norfolk
    I think they are normally supplied with a pair of suitable clips which are just plastic pipe clips and should be available at any good plumbers merchant or on fleebay.
    Ours is stored in the same way, vertically, in the washroom.
  3. jemhorn
    jemhorn Funster
    Nov 13, 2013
    410
    378
    Bideford, Devon
    Handle
    Brackets are supplied with new but I bought some similar from B&Q. From memory they are somewhere in tool department as they are used to clip long handled tools against a wall. There are a few sizes so take the handle with you. Good hunting!
  4. Wickolad
    Wickolad Funster
    Sep 10, 2013
    482
    541
    Wickersley
    As above, any good plumbers / dig store.
    Our handle fits in the vertical cupboard used for the fold up table, although there are no clips in there for secure fastening.
    Just be aware when positioning the handle, that the motorhomes main walls are usually made up of 3mm ply (interior) and insulation sandwich and therefore not an ideal anchor point to fit the pipe clips which only have one central screw hole. The side wall of a cupboard is usually 12 or 15mm lightweight ply, which should provide a stronger fixing point.
    Regards, Lance
  5. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,125
    3,541
    Eastbourne East Sussex
    My present MH is the only one I have had with a place to store it where it isn't on permanent view. It clips upright in the tall ski locker at the rear. Most have had it in clips near the hab door.
  6. Sidney
    Sidney Funster
    Jan 27, 2013
    1,301
    851
    Stamford
    I screwed mine (and the Fiamma rafter) to the aluminium bed frame - tidy, secure and out of the way :thumb:
  7. ludo
    ludo Funster Life Member
    Jul 12, 2011
    455
    773
    Lincolnshire
