Fiamma Awning Rafter (1 Viewer)
Nov 4, 2011
5,939
38,937
Uk
I don't think the rafter needs a fitting kit, mine hooks on parts already on the awning.
kglblue
kglblue
112
159
St.Agnes Cornwall
Coach built
6 years
Thanks, the rafter hasn't come yet and my van is covered up against the really bad weather.
g8ysn
638
417
ng219ep
coachbuilt
as stated the rafter comes with awning [mine did] u just release the nut to adjust
DuxDeluxe
14,658
72,783
Planet Zog
A woosh bang van
since 2008
Think it depends on the length of the awning. May not be with the shorter ones......
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Can confirm rafter doesn't come with 3m Fiamma awning but have added one & makes a difference & a lot less flapping :) Now just need a tube with end caps to store it (plus other long skinny items like flag pole etc)safely in our garage - looked at artists tubes but not long enough. The kind plumbers have on their vans for carrying pipes would do it but a bit too heavy duty & way too expensive - anyone have any ideas?
TheBig1
17,630
43,280
B&Q or plumbers merchants etc buy a length of plastic downpipe and a pair of caps
DuxDeluxe
14,658
72,783
Planet Zog
A woosh bang van
since 2008
We just chuck it in the locker together with the winding handle. Lays flat against the back so didn't really need anything to cover it. Might ask Mrs Deluxe to knit a cover for it, but then again like the basic good things in life, like breathing........... so perhaps not(y)
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
I recently purchased a rafter for our Fiamma awning, it came with 2 fixing brackets so it can be mounted/stored somewhere, i used some double sided sticky backed tape and stuck them on outer wall of the bathroom - as its directly behind the drivers seat - it sits there perfectly (its a good job really as there is nowhere else to fit it)
Oct 12, 2011
398
484
West Sussex
Lowline
Since 2011 therefore I'm not a newbie anymore
I store mine at the back of the garage with stick on Velcro . It comes in 1.5" wide and just stuck the sticky side ( the hooks) to the wall and then hold the rafter with the hook Velcro.. Use two sections one at top and one at the bottom of the rafter
Works fine with no damage to the rafter.
SandJ
1,799
818
North Yorks
Too long lol
I stored mine in the gap either side of door fitted nicely with winding handle on other side.
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Like the idea of fixing rafter with velcro but already have Fiamma & Easy Bed handles plus Fiamma Carrry Bike frame covering the available wall fixing space! Thank you scotty1 looks like a fishing rod tube will be perfect & cheap at under £7 delivered too(y) Bought this one Broken Link Removed
& some of this Velcro strapping http://www.ebay.co.uk/itm/131280965752?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT so will be able to fix to underside of bed frame that forms roof of garage. Ideal storage for other long, light fragile items too that might get damaged on the garage floor:)Knew some Funster out there would have the answer:D
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Fishing rod tube & velcro now all fixed & works a treat so now have great storage space for our Fiamma rafter & a few other bits & pieces (y)
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
I'd go to a local carpet shop and ask for cardboard inner tube. Then cut a some rubber bike tubbing for the ends..I wasn't a girl guide for nothing.
Minxy
32,656
66,564
E Yorks
Carthago Compactline
If you want to have even more storage under the bed get some cargo nets which you can attach onto hooks etc for storing light but awkward stuff - below are pictures of the garage in previous MH where I used this system, I also used them to keep stuff on shelves and also hold bits and pieces against the sides. The door storage was out of an old suitcase which was very useful!
Mousy
3,485
20,319
Sa15 2DG
Since 2013
I've got garage envy:(
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
We've got a garage like that :)Might have to steal this idea - cargo nets especially look ideal(y)
