Fap door handle/lock problem. (1 Viewer)
westy77
247
180
Hi, the Fap door handle on our motorhome is having issues with opening. It looks as though it's been replaced as the date on the rear is 2013 and the van is a 2005. The issue is from the outside I can't always get it to open! When the handle is pulled it isn't moving the catch far enough. I have taken it off to have a look and everything seems in order, the issue is the bar that is on the back of the handle seems to have a little play in the handle body (not sure if they are all like that?) so it's not pushing the arm far enough to fully open the catch on the door frame. I tried to put something over the metal bar to make it bigger so it pushes the arm further, but it then catches on the body of the handle. My thought is to try another handle? But they are not cheap! Is it easy to change the lock barrel over to anew one?
westy77
westy77
247
180
The camper is an Adria Coral 670SK. I'll get it off again later and get a couple of photos. It's like this one.
westy77
westy77
247
180
This is the lock that is currently fitted. The bar my finger is pointing at seems to be the issue. There is a bit of play where it is in the body of the handle. I'm thinking this is preventing it moving the catch the whole way over to open the door? As I put in the first post, this lock has been replaced as its got a 2013 date on it and it has different keys to the rest of the van.
Would I be wasting my time getting a new handle part? Do they all have that bit of play at that bar?
Thought I would put a photo of the inside part for reference.
Aug 8, 2023
Fiat Ducato Joint J1
I have exactly the same issue, did you find a solution?
Feb 27, 2011
14,741
76,049
Well that is an unfortunate brand name.
