- May 7, 2011
- 4,809
- 48,808
- T Line 785
- motorhoming since 1979
Just noticed this , as a different possibility to the endless breeze fan( a bit cheaper)
Fiamma Turbo Kit Cooling Fan
http://www.outdoorbits.com/images/fiamma/fiamma-turbo-kit-window.jpg
The Fiamma Turbo Kit is a caravan and motorhome ventilator and extractor that has two functions
It serves as a stand alone fan, or an optional fan to be fitted to most popular models of rooflight.
The Fiamma Turbo Kit is 12 volt dc powered and comes supplied with a telescopic and patented hanging system that allows safe and easy installation to rooflights such as Omni-Vent, Remi Top, Seitz Mini Heki and Midi Heki and Fiamma Vent 40x40 and 50x50 (when vehicle is stationary and rooflight is open).
The 12v connector can be reversed changing polarity and causing the fan to work as extractor and ventilator.
The Fiamma Turbo-Kit incorporates a large 24 cm fan and 2 telescopic hangers, which can be adjusted from 36 to 48cm.
The Turbo Kit comes Supplied with cable and cigarette plug connector and 12Vdc power supply cable for connecting to the motorhome's 12v supply.
Can also be powered by 8 x 1.5V type D batteries (not supplied) when in use as a table or hanging-fan.
Cost £55. against endless breeze @ £118
- Dimensions: 31cm x 36cm-48cm x 10cm
- Rooflight fitting: Rooflight apertures from 36 - 48cm.
- Material: Sturdy plastic
- Voltage: 12Vdc and 8 x 1.5v D type batteries.
- Absorbed power: 4 Watt.
- Fan diameter: 24cm
- Max. air flow: 7.2 m3/min.
- Functions: Works as a ventilator and extractor.
- Color: Ivory.
