External USB and tv aerial socket? (3 Viewers)
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
given up on google, maybe it doesn't exist???
I know you can get an external tv aerial socket, but can't find one for a USB. Ideally one unit with both.
I have 2 external thingys - a wifi booster which has a USB cable, and tv aerial cable. Rather than running through a window, am looking for a socket which has both? Failing that, just one for the USB as I know you can get an aerial socket. Can't find an external USB though.
Any bright ideas???
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
I have seen them on Amazon.
Cannot get link to work. Type in waterproof USB and you get the "Marine" ones
I'll bet there's room to cut a USB connector ( extension cable ) next to the aerial socket.
Gellyneck
9,248
18,340
More than toes wet now!
How are you looking to connect the back \ inside of the usb socket?
You can get panel mounted or case front usb sockets for a pc but they are generally 8 pin connectors.
Oooops beat to it by @Chipster
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
All those I have looked at re the above advice are actual powered usb sockets.
All I want to do is connect through a socket - instead of running the cable through a window. Ie. Plug into the outside and connect from the inside - same as a coaxial socket.
Camping Gaza
993
1,467
La Châtre, Centre-Val de Loire France
Coachbuilt Low profile
Converted a Fiat Ducato PV a while back
Not waterproof you would need to mount it next to and inside an external TV box if there's room. Or how about where you hook up? got room in there for a small hole where you could mount this? On the back side its a B type Square usb connector so jobs very easy to fit and connect no soldering.
Linky link:
Or this which is cheaper and says dust and water resistant:
Gellyneck
9,248
18,340
Ah so your wifi booster doesn't need powered.
The link from Camping Gaza above should suffice then.
Alternatively, you can get flat aerial and usb cable that go out the window and still allow it to be closed and latched if you don't want to be installing sockets.
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
It does, but the power is supplied to the router inside the van, then the aerial runs from the router to wherever it's sited connected by a USB cable. I just hoped there was a 'through the wall' USB connector but it doesn't exist!
Have ordered a tv aerial exterior socket and will feed the USB cable through that!
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Leave it for a few weeks - bet the Chinese will have one produced now you have generated a need :rofl::rofl::rofl:
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
I do not see there being a market of more than one for a combined TV and USB socket. You may be able to adapt a standard maxview aerial socket to give you a single TV and single USB. There are waterproof USB sockets or at least water resistant, but not when in use so I suspect not suitable for permanent use
Jan 28, 2008
10,122
18,391
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i fitted a chinese shower and steam cubicle for someone recently which had speakers and a waterproof usb socket
looked like they had put the usb socket in a tupperware picnic salt pot
32,673
66,651
You can get waterproof USB sockets for use on motorbikes etc, the below example has 2 USBs:
32,673
66,651
If your EHU inlet is on the same side as you want the aerial/USB you could place connectors in there as there's usually space to adapt the housing to fit them, it means you don't have to make any other changes to the vehicle's exterior ... no extra holes in the body work etc.
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
It's not, and that's not what I was after, despite there being loads out there of that type.
All I wanted to do was connect from outside to inside, just like a tv or staelite cable, not a powered socket - I have concluded it doesn't exist so will make one from a tv aerial socket ! Will Try to run a spare USB cable into an aerial socket and have the other end inside.
Appreciate everyone's efforts tho!
Chipster
1,008
1,121
East Midlands
Getting there!
Summat like this then? This is what I've used for similar application.
Aug 18, 2014
23,813
133,977
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Most shower units here have had inbuilt radios for as long as I have lived here. Not cheap.
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
Dave I use one of these to run my external USB WiFi antenna to the router in the garage, the barrel is long enough to go through the wall of our Rapido and fit the retaining threaded ring. It seems they are out of stock at the moment but may be worth an email or a further search.
Cheers
Ed
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Im with PaPaJohn, its seems none of the suggested are waterproof when in use :doh:
although all may work well from being fitting inside another form of protection(y)
32,673
66,651
... ie inside the EHU inlet housing ... now I wonder who suggested that! :rolleyes:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
From your comment maybe "You"?
But i would question the wisdom of running signals & data so close to the 240v
poss interferance via electrical disturbance
32,673
66,651
Yes I understand that but I know it has been done in the past by someone and they never reported any issues with it, it's just a suggestion but the op doesn't want to do it that way anyway.
