Expanding foam on underslung tanks (1 Viewer)
Welsh girl
3,658
3,036
Globecar
Since 2004
Can you use expanding foam to spray on our underslung water and waste tanks to insulate them ?
What else do people use?
Jul 28, 2010
1,710
617
The world
Small car
The yank tanks have foam every where. So I would say yes.
It's messy to do so I would say No
So it's up to you
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Ah, but if they do freeze, they'll be a bugger to thaw out!:Smile:
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
If you buy a foam gun and gun applied foam (cheaper) you can control where you spray it quite easy - once it cures you can then trim it with a saw :thumb:
http://www.toolstation.com/shop/Professional+Foam+Gun/p93227
you can find cheaper guns and foam but this save looking around and not that expensive :winky:
Once used leave the can on the gun it will be OK after a year or more ---not sure on insulation propertys of the foam but it will be a lot better than nothing ::bigsmile:
terry
Feb 22, 2008
12,266
45,055
Norfolk
Nearly Tugging
Since 2004
Self adhesive 12v tank heaters :thumb:
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Expanding foam can get easily get waterlogged so if used it would be a good idea to seal it with a bitumen paint of some sorts
Vlad.
TheBig1
17,630
43,324
i would be more inclined to fit stick on tank heaters, then use insulating foam board to box the tank in. its very lightweight good thermal properties and you can dismantle for maintenance later
Broken Link Removed
Feb 27, 2011
14,741
76,030
UK
Self Build
3 problems with the single tin types of spray on foam;
1) It is not 100% closed cell so will get waterlogged as previously stated.
2) It is not fire retardant. If you need some welding done underneath at a later date it is a git to remove first. If you don't you will end up with lots of nice little camp fires all over the places where you don't want them.
3) Spraying it on is a pain in the arse as it goes everywhere BUT where you want it to go. (2 part urethane foam is much better)
Personally if it was me I would look at insulation that comes in rolls or sheets. I would also look at some kind of 12v heating element.
I haven't bothered on mine. When it gets cold I detach the pipes as they come out from the van and put separate buckets under each one which get emptied very regularly. As a full timer I found that underneath is no place for water no matter how much insulation you have, it will always eventually freeze.
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
see if u can wrap it with a cylinder jacket much better insulation
