Engine management light (1 Viewer)
Will DAVIES
Fiat ducato auto trail
Hi can anyone help I have a auto trail camper 2005 with a fiat Ducato 2.8 engine when it's reving and working hard the engine management light comes on and some times it starts to hold back but if I ease off the throttle a little it goes out and it's fine
Will
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Sounds like the same problem I had with mine. The plugs on the end of the injector harness fail.
try removing them & spreay with contact cleaner, if it improves then get some replacement ends.
The dealer will try to sell you a new harness for £700 but theends are about £20 each.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
If itis that, then the part No. Is1350885080, like this.
Broken Link Removed
Other possibilities are turbo wastegate stuck shut, blocked fuel filter.
, blocked air filter.
43,331
49,463
Broken Link Removed
How odd......the seller in your link bought a pack of four but only needed one.
He has listed one lead but says he has another three in an unopened pack of four.
Confused !
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Confused !
The cannot pull off with vibration as they lock on.
The seller is me. I sold them, they came Individualy wrapped. I cut open the old one & it was blackened inside where it had been arcing.
