Emptying Fixed Tanks (1 Viewer)
Apr 13, 2013
73
76
Devizes
Since 2006
Hi.
Any advice on which campsites have facilities for emptying fixed tanks...grey and black? Think we will need to plan our trip by service points! Thanks for any info
S
The Coops
1,813
34,300
The Fylde
Adria Compact DL
Yes, thank you
Where are you planning on going would help as a starting point!
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Do you have a macerator and hose? That makes a massive difference. There are very few US style campsites with black waste gravity facilities.
sallys
Apr 13, 2013
73
76
Devizes
Since 2006
Hi. Yes we have macerator and 3m hose. We are touring Peloponnese. Currently on west coast but will be moving around for next 4 weeks
Nov 6, 2008
3,944
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
We have no problem emptying ours. Wherever there is a toilet, the macerator can be used. And if there is a sewer chamber, gravity is used.
Craig
sallys
Apr 13, 2013
73
76
Devizes
Since 2006
Craig
We have a 250l tank...so don’t think we can empty into a toilet. Need sites with a moho service point that can be accessed by a 9.2m van.
bigtwin
5,242
9,945
Derby
Concorde
Since 2006
Why not?
The U-bend is a water trap not a sluice valve.
Ian
Kannon Fodda
2,585
8,000
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
If you’ve seen the standard of Greek plumbing you’d know 250 l at once on a toilet would be asking for problems :(
Challenge is surely finding locations that have proper mains sewer connections not just to a sceptic tank or cesspit
bigtwin
5,242
9,945
Derby
Concorde
Since 2006
Why not? because the OP has a gravity discharge tank not pumped I believe.
If they have a macerator and hose do they still need a pump to dispose of via a toilet then?
You live and learn.
Seems limiting if a pump isn’t provided with such a system?
Ian
43,332
49,505
You live and learn.
Ian
Think it depends if its an onboard/in tank or external macerator.
Onboard won't pump externally but an external macerator may pump a long way
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Whilst, Ground level "facilities" are usually not the biggest issue, so long as you can get within your hose length of accessing the dump point, anything else, needs a pump. With my R-V I had a Macerator screwed to a piece of thick plywood, a short hose from the R-V tank to the macerator, and 30+ feet of flat hose. I never had a problem Neither in the UK nor on the continent.
These are readily available now too. come as a full kit and a carry case too. Amazon product ASIN B001HKZHIW
funflair
19,368
30,326
Guisborough
MORELO palace
since 2012
You live and learn.
Ian
Yes every system has its limitations, in this case the limitation is gravity so as already mentioned if you want to deliver it uphill you need a macerator from the tank and that will then pump it a long way. Usually you find where there is a cassette dump point there will also be a manhole but you might need to lift it.
