electrical power problem (1 Viewer)
ehuplad
504
93
North Yorkshire
Hobby 600
Hi All,
Have a issue with the fiver, when i plug into 240v after about 30sec to 1min it blows the trip.
I have turned off the trip on my vehicle for the 110 convertor and this stops it as soon as i switch back on 30sec to a min it trips again.
The question is how to i tell if it is the 110 convertor or the main board in the vehicle :Doh::Doh:
It is not a big problem as i have a 240v charger fitted so all the lights etc work from the battery and the charger keeps the battery charged.
So not sure what to do also were can i get a convertor 240 to 110 if this is the issue.
43,329
49,445
at home or on a site ?
has it only happened today and has it already been working on that particular 230v outlet ?
reason i ask is it could be the 230v RCD thats not working correctly.
ehuplad
ehuplad
504
93
North Yorkshire
Hobby 600
Unfortunatly done it on 2 sites yesterday and today one in England 1 in Scotland. ::bigsmile:::bigsmile:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
sounds very much like a problem of inrush current in the 110 transformer, a soft start kit required no doubt.
scotjimland
2,327
10,085
A Woosh bang
The first step is to isolate the appliances being fed by the transformer.. (TX)
Switch off the 110v circuit breakers (CBs) , then try again.. if the trip stays on then the TX is ok.
if not, it may well have an earth fault.
If that's ok, reset each CB in turn to establish which circuit is at fault .. it may be a fault with the fridge, air con unit .. or any other 110v appliance.
Try that and report back with results ..
Edit
It's not in-rush current if it takes 30 sec to trip.. that happens almost immediately ..
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
Hi All,
Hi there,
How did your induction go? do you know where you will be staying yet??
Ginny and Mike (suitcase sat system)
ehuplad
ehuplad
504
93
North Yorkshire
Hobby 600
Edit
Thanks Jim - tried that it still trips with them all off
scotjimland
2,327
10,085
A Woosh bang
I'm sure you appreciate, distance fault finding can only go so far, only point you in the right direction ..
If it's still trips with all CBs open, then it certainly looks like a fault with the TX .. but that's not conclusive, it could be as John suggested a faulty Earth leakage unit, a cable fault or dampness, but without inspection and testing it's impossible to say..
If your not familiar with electrical testing I would suggest having it looked at by a qualified domestic electrician. (not an auto electrician) .
43,329
49,445
as Jim said it could be a faulty hookup cable.
simple test......lay the cable out, DONT connect to the M/H but do connect to the hookup post.
if the post trips, dont use the cable until its been tested and OK'd
