Electric Step
Discussion in 'Tech/Mech General' started by Daisy21, Sep 27, 2011.
  1. Daisy21
    Daisy21 Read Only Funster
    Aug 22, 2011
    46
    7
    Berkshire
    Hi all
    Thanks for all the great advice/help I've received so far. New question for you technically minded people...
    Electric step for m/h door. This operates from a switch near the rear door. It works whether the leisure, engine or no battery is selected from the panel above the rear door so not sure which one it draws power from? Automatically retracts if it is out and you start the engine. Problem is that several times now when the van has been out on the drive it has refused to do anything! First time I had a problem it started to open but stopped part way, eventually it did agree to return to closed position. I thought it might have something to do with the engine battery being low as I had stupidly left the headlights on for a little while (engine started no problem though so battery wasn't flat). So I connected to the mains in the garage, flicked the charger on and switched to engine battery. Step worked fine. Now its done it to me again. Tried the switch and it was dead a couple of days ago. Van hasn't been driven much since last trip couple of weeks (just short ride last Friday to the dealership to get other issues checked out!) but I do go out to it most days to check the dehumidifier etc so step is used quite a bit. So thought to myself, I can solve this by charging the battery (gauge indicated battery was about 3/4 full before charging). So couple of days later (today) I go out to check step now working and turn charger off. Nothing! Start engine...no problem. Try changing the switch on the electrical control panel to leisure battery. Nothing. Decided to give up and left leisure battery on charger, but when I went to leave and tried it just one more time it worked. Initially it stuck, then retracted ok then worked fine. So question to you is: is this likely to have any connection to battery charge....or is the step temperamental/knackered?! :Doh:
    Thank you
    Daisy2
  2. rob kinnear
    rob kinnear Read Only Funster
    Nov 29, 2010
    175
    31
    Swansea
    Hi mine gives me the same problem and i have found that my issue was the switch not working properly ( easy to replace ) others have found that the micro switch on the step has been dirty ( on step under the van ) and all it needed was a good clean.
    I have bought a switch from a local dealer for under £10 and this has worked fro about 6 months and has now just started to play up again and I am now thinking that I might go to the manufacturer and get a genuine part as it may last longer.
    I hope this has been helpful I know there have been other threads on this in the past
    Rob
  3. rob kinnear
    Nov 29, 2010
    175
    31
    Swansea
  4. MHVirgins
    MHVirgins Read Only Funster
    Aug 22, 2011
    3,890
    3,165
    South of Scotland
    Hi Daisy2
    We had a similar problem with ours whereby it came out partly and then stuck:Doh:
    We put some WD40 on it and this seemed to do the trick, so it may have been mechanical and just needed clearing or a bit of lubrication.
    Good luck:thumb:
  5. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    If you look underneath the step when its open and if you can see a small push post the the step will touch when it is closed, them press it a few times it will be a micro switch that is inside the plastic housing for the step.
    The post sometimes gets a little stuck and stops the micro switch from closing. If this does not work then you may have a different system then mine, but the symptoms you describe are the same as I some times have and it works for me.
    Doug...
  6. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    This problem sounds more like a faulty control switch, the 2 way up/down switch, you can buy these from car shops for a next to nothing, they are used to control the windows.
    I have to replace mine about every 3 years.
    Doug...
  7. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    I don't think it is the switch, try exercising the push post to the switch, and the switch itself can be bought for a pound or two from some one like Maplins complete with postage.
    Doug...
  8. Daisy21
    Aug 22, 2011
    46
    7
    Berkshire
    Thank you so much for the suggestions. Been crazy at work this week so not been able to get out to van in daylight! Will take a look over weekend and see what I can achieve :BigGrin:
    So glad I found this site....you are all brilliant :thumb:
    Daisy2
