electric step problem
Discussion in 'How To' started by margcal, Aug 4, 2011.
  1. margcal
    margcal Read Only Funster
    Jul 28, 2011
    Scotland
    Electric step on My Laika motorhome keeps sticking. Bottom step doesn't fold enough before top step starts to fold. Result is I have to manuually close bottom step as mechanism is closing. One of these times fingers are also going to be folded up manually!! Any suggestions?:Doh:
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,959
    17,634
    YO11 2BD
    lubrication !!!!
    instructions for my step states 'grease all pivots and links every 6 weeks'
  3. pappajohn
    Aug 26, 2007
    29,959
    17,634
    YO11 2BD
    welcome to the fun by the way :thumb:
  4. rob kinnear
    rob kinnear Read Only Funster
    Nov 29, 2010
    175
    31
    Swansea
    There is a micro switch under steps check if that is clean . I have had an intermittent problem with mine not retracting and I installed a new operating switch inside the van. Cost about £8 from
    http://www.vanplus.co.uk/
    They are local to me but do mail order
    I hope this is some help.
    Best of luck
    Rob :thumb:
  5. margcal
    Jul 28, 2011
    Scotland
    Thanks have tried oiling / greasing but no improvement.
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,344
    7,468
    Nr Watton in Norfolk
    It may need cleaning before lube, they pick up all road dirt
    Brian
  7. wiff2110
    wiff2110 Funster
    Aug 4, 2011
    9
    surrey
    It needs to be clean of dirt at the moveable areas, give it a good brush out and then apply some WD40, if there is no dirt or fine grit in the mechanism it should improve the movement. The WD40 will dry out so then give it some penetrating oil. hope this helps.:thumb:
