Elddis Fire Storm Tow Bar (1 Viewer)
degs
Merseyside
A
Is it possible to buy a tow bar to fit a 2009 Boxter van and fit to my motor home, a van T.B. is £75 and one for the Elddis is £250 odd. I am happy to cut and weld if necessary.
Degs.:Smile:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
on some conversions the chassis doesn't go all the way to the rear of the bodywork.
if you have the alko chassis you must not drill it in any way shape or form but there are towbar fixing points on the side of the chassis on these.
i had a basic towbar fitted to my motorhome and all it really seems to do is catch the ground however i am going to address this issue shortly
depending on which chassis and the fabrication ability you have you may be able to make your own to fit from suitable channel & box section steel.
i have seen so called professional motorhome towbars that are nothing more than a 14" piece of 4"x 6mm channel section with 2 pieces of 50mm x 50mm x 4mm box section welded to it then a bit of 50mm x 50mm welded across the rear of these with a towball fitted in the centre.
the electrics cannot be just tapped off the rear lights due to the canbus system and have to have a bypass relay fitted.
scran
701
83
washington
a class
drilling chasis
why do you not drill alko chasis
43,330
49,446
An Alko chassis is hot dip galvanized and will last for years without rusting/rotting, drilling it will be a route for rust to penetrate the steel....and the rot warranty will be void.
spraying, after welding or drilling, with galv spray is not good enough.
43,330
49,446
I made my own bar for the Kontiki......60mm x 60mm box section and 10mm steel plates to fix to the chassis.
a few pics of the fitted bar which had been on around a year, shame i skimped on quality paint though :Blush:
the plate appears to be bolted to the bar but it is welded as well...the bolts are to hold the lot together while it was removed and welded.
Noted the condition of the unpainted ten year old Alko chassis...proper galvanizing
D
degs
Merseyside
A
Tow Bar
Many thanks I will have to get my welding machine out.:thumb:
