EHU--STILL can't make it work. (1 Viewer)
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I still can't get the EHU to work.
Handbook mentions a main switch--I've searched the van--no switch that I can find.
No main switch is shown on any diagram.
Where the lead goes into the m/home side there is a blue "hook" next to here the plug goes in--anyone know what this is?
It is so cold here that I've run an extension cable through the passenger window and connected up an electric convector heater on lowest setting. Will this be OK at night?
Could I have a duff EHU lead?
I am :cry:
43,330
49,446
could be a duff lead...
the main switch will be on the mains consumer (fusebox) unit along with the other circuit breakers.
how do you know it isnt working on hookup ?
have you tried plugging something into a socket in the van ?
may just be the 12v side which isnt working on hookup.
the blue 'hook' is a locking tab so the blue plug cant just be pulled out.....you need to lift/press the hook to remove the lead.
if you can pull out the lead without pressing/lifting the hook, then it aint plugged right in and could be the problem.
convector heaters aren't the best thing to be left unattended.
scotjimland
2,330
10,098
A Woosh bang
Must be main switch somewhere..
wherever the ehu socket is mounted on the outside of the van try looking inside directly behind it.. usual places.. = under a false floor in the wardrobe.. in a locker... under a bench seat ?
S
stagman
I am :cry:
The blue hook you mention sounds like the plug release . Do you have a light on your charger , what voltage is showing on your leisure battery . Yes you could have a duff hook up lead amongst other things .
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Do you have one of these ?
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
The blue hook you mention sounds like the plug release . [HI]Do you have a light on your charger , what voltage is showing on your leisure battery .[/HI] Yes you could have a duff hook up lead amongst other things .
Sorry--I don't understand the bit above.
The leisure battery has been charged up by the solar panel in the day so is saying 85% at the moment.
It's possible then that I haven't pushed the lead in properly (weak muscled woman here!!!!)
Dark now so will try again in the morning.
On the main control panel there are 3 fuse switches that say 12V and next to them 1 that says 220V. they are all in the ON position.
Thanks everyone for your replies.
43,330
49,446
the one labelled 220v.....switch it off then back on again....may be a faulty internal contact in the breaker.
the blue plug can sometimes be very difficult to push into the hookup point....you should see the hook move a bit as it locks the plug in place...a bit like the latch on a garden gate.
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
Blue hook on left hand side of socket on our van, you lift it to release the cable. If you are able to pull out the cable without lifting this to do so, then maybe you dont have the cable pushed in far enough and are not connecting it correctly in the first place?
Ours is a bit tight,going in and coming out.
worth a check
regards
Steve
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Thanks PapaJohn
As it's now dark (no street lights here) can I safely leave my extension lead with heater on for tonight and I'll follow your steps in the morning?
S
stagman
I would imagine that if your hook up was charging your batteries you would have 100% reading but not sure on the Benimar charging system I have a reading of around 14.8 volts on my meter when on hook up . When you push your hook up cable in you should hear that blue clip click to hold the plug secure n and you should not be able to unplug without pressing the clip to realease .
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Definitely looking like use failure on my part :Sad: Will try again in the morning when it's light.
Thanks for your help. Much appreciated.
43,330
49,446
Thanks PapaJohn
a convection heater is safer than a fan heater but I still wouldn't be too happy leaving it on unattended.
if you must, then ensure it cant fall over if it gets windy etc as it could then overheat.
ideally an oil filled radiator is safest of the lot, but they have been known to leak oil so should be stood in a metal tray to catch any leaks.
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I'll go out and check it but it's very stable, not close to upholstery so I think it should be as safe as it'd be in a house. With the wind chill here night temperatures are down to -15.
Thanks for all your advice.
Roll on Spring.
43,330
49,446
I assume you haven't drained the water system ?
if you have, then it wont matter a lot if you have no heating in the van.
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Water was supposed to have been drained when I picked it up but after reading the "purging" thread on here I was concerned. took it over to the man who is going to change the gas for me and he said water had been left in pipes and although there was ice in pipes, he thinks they are all OK. He lent me a convector heat to put in it and suggested keeping it warm at night. He is going to change the gas over for me in a couple of weeks and will go over all the pipe work to check it's all OK.
43,330
49,446
i dont know prices in France but it may be worth buying a smallish oil filled radiator for the van.
preferably one with multi heat settings and a thermostat.
set for maybe 300w and the stat set at 4 degree's.
that way the heater only comes on when its below 4deg and switch's off above 4deg, and is seriously more economical to run than a 1/2/3kw convector.
1,710
1,970
Leicestershire
4 and many as a tugger
worth a check
regards
Steve
I would go with the above. On our Autotrail, I ended up removing the spring loaded cap from the plug as it got in the way. With it on it made inserting the plug far enough to make contact very dificult.
1,204
741
West Sussex
Burstner Nexxo T740
since 2008
On our current MH I have to lift the cap in order to push the plug into the van socket. I also have to lift the cap to release it to remove. It may be this thats not connecting........
