Ehu amps question too! (1 Viewer)
Soozywoozy
534
452
Oxfordshire - edge of the cotswolds
Hymer B 704SL
2014, 2 motorhomes
Similar question to SMB, we have has the dometic freshlight air conditioner installed for our jaunts down south (plus wishful thinking for uk!)
The blurb say " The air conditioner has 2100-watt cooling capacity for 230-volt stationary operation"
But then Technical Data:
Cooling capacity (kW) 2.2
Capacity (BTU/h) 7500
Power (V/Hz) 230 / 50
Consumption, cooling mode (W) 950
Consumption, heating mode (W) 1200
And apparently low energy start up.
Lights are all LED, fridge/ freezer AES, TV is 12v
How many amps do I in theory need please
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Cooling mode 950/230 = 4.13A
Heating mode 1200/230 = 5.22A
It's a heat pump (like all fridges / decent aircon units) so the power is used to shift heat from one place to another rather than providing heating or cooling directly. Hence the output in Watts is higher than the input.
2,598
19,237
Tyneside
Chausson best of Flash 10
Several years now
Or to be on the safe side, you might consider towing a medium sized generator. :Smile:
