Eclectics in MH (1 Viewer)
Paul an Jane MK
435
486
Milton Keynes
Elddis Encore 255
enjoyed the freedom over the last couple of years but still Wish we could have got away more often
Either something majorly silly or a wind up.
I only used a qualified electrician once and he tried to set fire to my fuse box by not doing up one of the connectors so it arced away nicely.
Gone back to doing myself
Oct 7, 2015
737
3,578
newark
Swift escape 624
Hi is the plug on the hoover the type which has insulated prongs except for the tips as if so they will not always make contact in some sockets
Scout
3,959
121,327
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
I would like to piont whilst this tread is about Hoovers other floor cleaning elecrical devices are availibel, we dont want to be accused of af blatant advertising do we:rolleyes::cautious::sleep:
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
@SC 05 OUT you are totally right there is also the good woman,and you dont plug here in :whistle:
Jaws
23,836
72,490
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
i don't understand this maybe someone can help, I plug the orange cable into a socket in the garage and the MH it runs a kettle and a T.V when I use the sockets in the MH, if I plug in a hoover or anything else it wont turn on, any idea what going on, anyone :confused:
thanks in advance
crabs
No matter how many times I read this I am baffled.. not only by the question but a lot of the replies !
The orange cable.. It is a normal hook up cable ?
You are plugging it in to the motorhome in the socket on the side of the van where it is meant to go yes ?
You say that IT runs a tv and a kettle.. Where are those plugged in to ?
Are they plugged in to sockets in the van ?
Are you saying that if you plug a hoover in to the same socket as the kettle it will not work even though the orange lead is still plugged in to the same things ?
Paul an Jane MK
435
486
Milton Keynes
Elddis Encore 255
Err, did you quite mean to put it like that? :censored:
I try not to burn my house down, I make sure I tighten all contacts properly LoL.
What made it worse got home from a boys night out with a kebab to find none of our lights working, checked consumer point to see if it had tripped and realised I could hear crackling and smell burning (not a good sign) by the time I sorted it I had a cold kebab
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I think the sockets are wired to an inverter.
The inverter only has the capacity for a kettle but not the hoover.
Armytwowheels
6,475
14,877
Market Harborough
Carthago S Plus - Iveco
Since 2011
[/QUOTE="jonandshell, post: 1898960, member: 14648"]I think the sockets are wired to an inverter.
The inverter only has the capacity for a kettle but not the hoover.[/QUOTE]
I suppose the OP could try running the kettle without the orange hook up cable plugged into the side of the van, if it still worked he would know own there was an inverter hidden and working somewhere in his van.
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
Which inverter is strong enough to power kettle and boil the water??
Hoovers weaker than kettle , common sense!
If kettle works from socket but the Hoover does not ( from the same socket) then fault lies with the Hoover, try the fuse, open the plug check connections, plug somat else instead!!
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
Jaws all you post is correct, it is plugged into a socket same which boils the kettle or the one that works the T.V, nothing happens , not only did I try a hoover but a thing that blows up air beds that would not run either, I am sure that as Amy says there is an inverter hidden and working somewhere in the van, going to check it out again today with one of the local inbreds, :LOL: I will post and tell the story if we sort it, it has to be something simple I am over looking, darn easier to sail and navigate the seven seas
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Common sense? Sorry don't get that.
We have a 1000w kettle, as do many hotel rooms.
An average vacuum cleaner is around 1600w. Add to that that an electric motor has a large startup current, your argument becomes a sweeping statement made with no knowledge of all the facts.
Louis
1,204
982
Anglesey
The difference being , one is a motor the other a boiler, common sense dictates that if you can boil water in a kettle in the normal time - an electrical motor will definitely spin but not necessarily at the designed speed hope that clearer?
Louis
1,204
982
Anglesey
And you have?
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Err, no. The high startup current will just cause the under rated inverter to switch off. Either that or the voltage drop caused at the supplying battery will cause the invertex to shut down.
Either way an inverter will not run an appliance which exceeds its maximum output.
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
lets wait for the sparks to check it out and then we will know the facts, (maybe) ;)
Louis
1,204
982
Anglesey
I
nverter would not switch off, I'm sorry these are facts I have experienced
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
sparks is off ill, he was wiring a house yesterday and his side kick plugged the fuse back in while he was holding the live wires, what a blast, anyway he was not to badly shocked hope he will be here this week :mad:
scotjimland
2,335
10,105
A Woosh bang
and you trust hime with your van.. :eek:
sounds like a house bashing spark.. any electrician with a modicum of training would have ensured that wasn't possible..
i.e...Lock off DB and or keep fuse in pocket.
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
ok your not going to believe this after all my efforts to work things out my brother comes along and switches on the socket for the T.V I plug in the hoover and away it goes flat out, we tested all the electrics were working and they were, only 1 hour before I had all the problems posted above by me, I will get the sparks to check to a loose wire in the system, once he has got over his shock, so all I can say is sods law if there are no loose wires, I had not moved the MH from its previous parking position. :cry:
May 8, 2016
1,685
80,930
silver coast, portugal
C Class: Low profile
Boatie for 20 years
Faulty socket, faulty socket wiring, replace. No drama.
Most importantly, no need to call an eclect-rician
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
true pyro, now shall I do it or call in Idwall our local sheep sheerer and owner of green wellington boots which I see him wearing at night in the fields, I wonder what he's up too chasing those sheep in the dark :D
Louis
1,204
982
Anglesey
Keeping the sheep away from the sheep worrier who's been there at night :whistle:
